You are incorrect in your assumption that there is no consensus on the role of humans in climate change. The overwhelming majority believe that humans are driving the phenomena. If you can provide peer reviewed scientific articles/associations that say otherwise I would like to see them.defenestrate wrote:I'm aware that the climate is, has been, and will continue to change. So are many scientists. Most sources use this as a basis to assume that scientists also agree that man is largely responsible, when this is often simply not the case.
Continually beating the same drum about "EVERYBODY KNOWS AND AGREES SO CONVERSATION IS NOT IN THE BEST INTEREST OF SCIENCE" does *not* support the scientific method in any way. It is the standard tactic of politics on almost all scientific or pseudoscientific matters. And having Al Gore, the UN, and some scientists run around telling people how to live their lives while many of the major proponents get rich off of these ideas, no matter how difficult to make these changes are for regular people, is neither science nor human progress. It is pretty much cult-like behavior. That the country that was founded on freedom of (and from) religion is skeptical should not be that alarming.
Here is an abstract from the The Proceedings of the National Academy of Sciences, published April 9, 2010.
Although preliminary estimates from published literature and expert surveys suggest striking agreement among climate scientists on the tenets of anthropogenic climate change (ACC), the American public expresses substantial doubt about both the anthropogenic cause and the level of scientific agreement underpinning ACC. A broad analysis of the climate scientist community itself, the distribution of credibility of dissenting researchers relative to agreeing researchers, and the level of agreement among top climate experts has not been conducted and would inform future ACC discussions. Here, we use an extensive dataset of 1,372 climate researchers and their publication and citation data to show that (i) 97–98% of the climate researchers most actively publishing in the field surveyed here support the tenets of ACC outlined by the Intergovernmental Panel on Climate Change, and (ii) the relative climate expertise and scientific prominence of the researchers unconvinced of ACC are substantially below that of the convinced researchers.
