Show your mods!
- Half Sack
- Location: Alberta, undisclosed location of the Weapon Plus Program
Good replies thanks, it does seem its the blade "kick" meeting with the lock bar is the issue. I tried using marker on the blade tip and didn't see any on the handle, could be the marker wasn't wet enough to mark the handle but trying to look at it, seems the issue is the lock bar blade area.
Whats good for shaving an H1 blade down with a dremel? Its all I have.
Then again I could start with the handle like Hunt did, its just plastic, easier to start there especially if your telling me that is the issue. Why ask if I'm not going to listen right?
Welcome to our newest member, Half Sack
:spyder: Endura4 wave, Ladybug Hawkbill H1, Byrd Hawkbill, PM2 digi camo, Sharpmaker *Sprints: Dodo Orange, MeerKat Burgundy, "R" Nishijin *Discontinued: Caspian H1 :spyder: #ByrdWeek Winner :cool:
No one likes the dark - Robin Sherbatsky
*Signature not updated, purchases missing...*
Did you make those backspacers or order somewhere? I would like the same open back for my org millies.
vadel wrote:Modded Military CTS-XHP
- black painted spacer >>> normal backspacers with modern design and very high-tech looking
- pivot screw >>> alien-head custom screw. polished screw and pivot head. veeeery high-tech looking
- torx-6 >>> good torx-9. slightly polished. better look, no more chance to break screws
- new (better quality) screws for clip. slightly polished
- little work with clip. deleted fins and factory defects on clip's edge
- red fiber "tuning tag" under clip. with hidden unique number and my signature
I see the atoms free and fine,That bubble like a sparkling wine; I see the songs Electrons sing,Jumping from ring to outer ring;
-Lister
-Lister
Lady Bug Sheaths
I know this has been done before, but I am very happy with the way these turned out.
I have a home made Kydex press and do make a few sheaths and holsters.
I had some Desert Sand .08" kydex scraps lying on the bench and said to myself "self, there is just enough there to make neck sheaths for a couple of Ladybugs".
I have an older version in Forest Green that has a slightly different shape to the head than the two later models I have. I also have a Jester in Black FRN (NIB) and may make an orange sheath for it.
So, I cut the pieces, heated and pressed, riveted the top, shaped on the belt sander, and added Paracord with break away barrels for safety.
The Ladybugs are so light, the sheath only needed the rivets at the top. This also makes the knife easy to pull and insert. They "click" in.
The Forest green is mine, the black is for my youngest daughter for Xmas. I purchased a Victorinox Black Spartan for my Son in Law.
Stocking stuffers.
Anyway, here's the pics.
and here is my Daughter's Xmas present by itself.
Chea...er.... inexpensive gift ideas ROCK!
Stocking stuffers.
I have done this before but I wanted a good feel for my ol' para, so here we have a single point clip, heated stainless steel and a ziptie mod. Love it :)
- Attachments
- PB200088.jpg (100.38 KiB) Viewed 5877 times
- PB200098.jpg (91.21 KiB) Viewed 5864 times
- PB200094.jpg (97.91 KiB) Viewed 5864 times
- PB200091.jpg (99.39 KiB) Viewed 5886 times
thewannabesurvivalist
- all screws >>> TORX-8
- red vulcanized fiber inserts, and accompanying works - modification of seats of barrels, adjustment of length/depth of threaded connections, adjustment and polishing of elements of a handle, change of seats under screws, preparation for installation of additional accessories
- clip's mod: clearing of a factory paint, elimination of defects of edge, change of seats under screws
- nine add screws-"caps" for empty holes
- Audit of the pivot mechanism, exact adjustment and polishing of surfaces on purpose to remove cracks between plates and the back-lock
- some polish work...
My :spyder:s: C85G2 (EDC), C63GPS, C63GPS2, C63GP3, C65CFP, C65BKP, C65TIP, C143GP, C90PBLE, C90CFPE, C10PGRE, C10PGRE FFG, C10SGRE, C11PGRE, C10JBB, C11JBBP, C11JBOP, C113CFPD, C28PGRE2, C149GP, C135GP, C126GPFG, C36GPBNXHP, C36CFM390P, C81GGY20CP2, C46GGY, C79OR, C142GP, C122GP, C136G, C148G, C28T, LSS3T, C150GP, C95G2
vadel wrote:- all screws >>> TORX-8
Love the look what kind of material is that red ?
- Spydesense
Very nice!vadel wrote:- all screws >>> TORX-8
My :spyder:'s>> Fluited Titanium Millie, M390 Millie, Brad Southard, Gayle Bradley, Junior, Bushcraft UK, Translucent Blue Manix 2, G10 UKPK, Sage 1, Sage 2, Ti Damascus Delica 4, Orange FFG Endura 4, Gray FFG Endura 4,Native, Blk Dragonfly, H1 Dragonfly 2, Blue Tenacious, Tenacious, H1 Ladybug, White Ladybug, Grasshopper, Honeybee and Bug
Vadel, that thing is beautiful. I like the screws in the empty holes! Also, the red liner viewable through the skeletonized scale looks nice.vadel wrote:- all screws >>> TORX-8
-Brian
A distinguished lurker.
http://en.wikipedia.org/wiki/Vulcanized_fibreHeespharm wrote:Love the look what kind of material is that red ?
Thanks. To poor mans stone wash put the blade in some ferric acid for 20 seconds or so to darken, wash it off put it in a bottle with some rocks a little water and soap and shake away. I cheated and used a small rock tumbler my wife got off ebay. :DNiles wrote:Nice work. I've never been a big Byrd fan, but that looks great. How's the poor man's stonewash work?
- razorsharp
