aicolainen wrote: ↑Thu Feb 09, 2023 3:14 am
I tend to agree with vandelay, not because mushroom is wrong necessarily. It's just that people are different, use stuff differently and has different needs and habits.
When I got my PM2, it was easier to operate with gloves than the liner locks I had at the time, so it's not bad. In time though, I've just found back locks to work best. No matter how cold, greasy or slippery my hand is, I can always operate it in a manner that is intuitive, predictable and safe.
Now, I didn't really want to add to this lock safety pissing contest, but all this chatter finally made me realize something and I wanted to add a little context to put my rationale in perspective. Currently I hardly have any liner locks at all and certainly nothing that comes even close to the unapologetic, no nonsense approach of the M1. With the coach fidgeters making up ever more of the knife market, it's not hard to see how this breed might go totally extinct. I'm not sure that in itself is a valid justification for me to get one, but it sure does add some weight on the scale.
When I became aware of the rumored DLC 4V SNK exclusive, that did actually seem like a good match for a M1 if I ever were to get one, but this discussion has got me to think otherwise. While 4V is probably a good match for a folder of this size, it's probably not for how I'm likely to use it.
So this got me thinking, and this tune is probably getting a little boring by now, but MagnaCut would be a really sweet option for the M1. So maybe Spyderco could/should honor this design and let it go out with a bang. That would surly smack me right down off that fence, and I would assume quite a few others as well.
Just a though. I'm sure no one else has thought of that :)
Im not concerned about which lock is better with gloves on. I really couldn’t care less about that and it’s not a part of the point I was trying to make.
I agree with you - people are different, use stuff differently, and have different needs and habits but the one thing they all have in common is that they’re required to put their finger in the path of the blade to close a liner lock. Something that’s not required on a compression lock. (Of course using a foreign object is a possibility but to suggest that as a reliable alternative is just being contentious)
It’s not a contest either and there’s nothing to add. The simple fact is the compression lock provides a safer means of operation than the liner lock. I don’t believe it’s up for debate either. Until someone can logically and rationally explain to me how having your fingers in the path of the blade is objectively safer than not having them there, I’ll maintain that belief.
An analogy that I like to use is closing a knife is like walking from point A to point B. Path One is on a highly trafficked road without a sidewalk and Path Two is on a highly trafficked road with a sidewalk. It is possible to safely walk from Point A to Point B on either path but the risk of getting hit by a car is higher on Path One and Path Two offers a safer way to get there.
It’s similar to lock strength, it is up to the end line user to decide whether or not keeping their fingers out of the path of the blade matters to them but it’s still a risk that can’t be removed. (Although saying that gives me an idea for a liner lock concept that doesn’t require fingers in the blade path
vandelay wrote: ↑Thu Feb 09, 2023 10:13 am
Mushroom wrote: ↑Thu Feb 09, 2023 2:14 am
Whether or not you can personally see a situation where it happens is irrelevant. The fact is, the chance of an accidental cut is higher when your finger is in the path of the blade than when it’s not.
If the design blocks the blade from hitting your thumb, you're not going to get cut closing it unless you take an extra step to move it into an unsafe portion of the blade path. You could always do that as a result of the knife slipping, but you can do that on any lock.
That’s unfortunate for you that you can only move your thumb to the side while operating a liner lock but lifting it up into the actual edge is a real possibility for people with more range of mobility in their hands than yourself.
I can't move my finger up because there's a flipper tab in the way.
When I cut myself on a dragonfly, it was one of the fingers that wasn't in contact with the choil, so I was able to move it up into the blade.
left handed operation does not require fingers in the blade path nor does gloved operation.
could you post tutorials on how to do this? I'd like the lock more if I knew how.
Right - so if I’m understanding you correctly, you’re saying “…you’re not going to get cut closing [a liner lock] unless [an accident happens.]” In that case, thank you for agreeing me with me because we’re right, there
is a higher chance of an accident happening when you’re required to put your finger in a position where that’s possible!
Then - “When [you] cut [yourself] on a Dragonfly, it was one of the fingers that [was in the path of the blade.]” Yes, we’re on the same page, that’s what I’ve been saying is the safety hazard.
Lastly, to keep it brief, pinch the knife between your index and middle finger then actuate the lock with your thumb. If the blade doesn’t drop shut, use your index finger to push it closed.
