I am sure Larrin will specify it if it makes sense to have it. Not sure what it would be needed for in a stainless knife steel produce with powder metallurgy process. MagnaCut doesn't have it as don't a bunch of other well performing steels used for knives.Brant wrote: ↑Fri Jan 12, 2024 4:05 pmThe first thing is that every steel that I’ve found that has “wear” in its name has a bit of tungsten in it. Second, I just like steels that have it in their chemical make up. Let’s all hope however it turns out, it’s really affordable to make and sell.Barmoley wrote: ↑Thu Jan 11, 2024 9:45 pmWe don't know what's in the mix yet, but for what purpose do you want tungsten in the mix? Tungsten in high alloy steels is usually there for high speed steels for them to not loose hardness at high temperature. When a lot of chromium is present tungsten doesn't produce harder tungsten carbides, so vanadium or nobium are more effective in creating harder carbides. For knives operated by hand using these is more effective to increase wear resistance than using tungsten.
MagnaWear Easter Egg?
Re: MagnaWear Easter Egg?
Yeah he developed it with a group of people with some being from Europe(possibly Germany but don't remember for sure)
Dr Larrin stated before something about having versions of Magna Cut to have stronger properties in different areas. I want to see Magna Tough (TM)
MNOSD 008
Hope it gets as much love as magnacut
