Spyderco Manix 2 Lightweight
engine
Re: Spyderco Manix 2 Lightweight
#41
Post by engine »
Mon Mar 27, 2023 7:55 am
congrats! it's really a great knife.
Thank you ladybug!
And its very sharp from box..
engine
#42
Post by engine »
Is WD-40 good for maintenance and lubrication of Manix2 ?
#43
personally, i wouldn't use wd-40. i use frog lube paste on the blade if i'm worried about corrosion because it's food safe. i use either kpl or daiwa reel oil on the pivot, bearing, and spring if necessary.
#44
I have experienced WD-40 to get gummy with time.
#45
engine wrote:
Wed Apr 05, 2023 2:32 pm
Just my experience, but I would not lubricate the Manix 2 LW at all.
I did in the beginning with my REX 45, cause I was worried about potential rust in the pivot area with that tool steel and given that- unlike you with the now screwed model - I cannot disassemble my Manix (pins).
Turned out to be not necessary at all - action good without lubrication, no rust as far as I can tell (i could imagine that the pivot area has kind of a "self cleaning" function due to the frequent rotation and slight friction. Just a guess though).
IF I lubricate a folder: I have good luck with Victorinox multitool oil, can only recommend it.
engine
#46
Post by engine »
