Steel Poll - What new steel would you like to try/test on a Spyderco Mule Team knife
What steel you'd like to see/test on one of the upcoming Mule Team knives
M398
8
8%
CPM S125V
7
7%
REX121
22
21%
Vanax SuperClean
57
55%
Your own variant (specify in comments)
9
9%
Total votes: 103
Josh1973
Re: Steel Poll - What new steel would you like to try/test on a Spyderco Mule Team knife
#41
Post by Josh1973 »
KKnives_Switzerland wrote:
Sun Jun 20, 2021 11:41 pm
Bolster wrote:
Sun Jun 20, 2021 10:40 pm
Sun Jun 20, 2021 10:15 am
I throw in S390 Microclean.
Thanks for the graphic. What does it mean when one steel has several datapoints of different colors?
Pete tests several different sharpening systems. On the upper right corner, there is a key which tells which is which: https://docs.google.com/spreadsheets/d/ ... 1607644856
Hello KKnives_Switzerland. As much as I love to watch Pete do testing. And respect his testing and the man himself. I am a bit confused over some of his results. Compared to my lighter duty real life use.
Point in case is the Sandrin cemented Tungsten carbide knife he tested. I bought a Sandrin Torino due to watching his video a year ago. Doing over 1,500 cuts on Manilla rope with the TCK model. Remind you I never used the knife prior to this except to do a paper cut test in which it performed marvelously.
Well the kicker for me is that I cut about 9 or 10 soft wood branches and the razor sharpness and work sharpness both both left completely and snagged on a paper cutting test. And the working edge was not that impressive. I sent it to the Sandrin represenative factory to have it sharpened and that alone ran over $20.
Anyways I noticed they re sharpened the blade to a different angle from original factory. I used the Torino again to cut a few small softwood branches. Same end result. And disappointed.
I ended up putting the knife in the dresser drawer and retiring it after I noticed the knife lost it's sharpness yet again from light use. And miserably failed the paper cutting test despite seeing no damage or flat spots to the blade from inspecting it with a 5x magnifying glass.
I cannot explain how disappointed I was. When I got D2, S35V, and CPM154 that did a day of actual hard work and still could slice paper and shave some hair from my arm without touching up on a honing steel.
KKnives_Switzerland
#42
Post by KKnives_Switzerland »
Josh1973 wrote:
Mon Jun 21, 2021 10:26 am
The problem with cemented carbide is lateral force I found. I did some testing with various carbide grades on "my road to elastic ceramic" and actually had similar, albeit not quite as bad results like yours. The apex seems to "flake" off on a microscopic level. Steel - and now the elastic ceramic - can take lateral force much better than carbide. That's why I show brass carving right away in my "abuse testing" video about the elastic ceramic.
Josh1973
#43
Post by Josh1973 »
Mon Jun 21, 2021 10:45 am
Bud. Thanks for replying and explaining lateral force. I never experienced anything like this in my life. I can't wait to see your folding knives come out. I look forward to purchasing one. And I hope you do a slipjoint version down the road.
Wishing you and your family a great week ahead.
Sincerely. Josh1973
KKnives_Switzerland
#44
Josh1973 wrote:
Mon Jun 21, 2021 10:50 am
Sincerely. Josh1973
Thanks same to you! :)
#45
Could elastic ceramic show up on router bits and saw blades eventually?
KKnives_Switzerland
#46
Bolster wrote:
Tue Jun 22, 2021 10:21 am
Yes.
kodai78
Location: “Beam me up Scotty, there’s no intelligent life down here.”
#47
Post by kodai78 »
Is a dendritic Cobalt Mule possible? I know it’s not steel. It’s better!
:spyder: Shaman REX 45, Smock, Baby Jess Horn CE, Spydiechef, Schempp Bowie,Ti Fluted Military, Titanium Military, Native S30 V and G10, PM 2 in S35VN, and S110V, Manix 2 LW BD1 and SPY 27, Sage 5, Positron black CPM S30V, Chaparral w/Raffir Noble scales, SuperLeaf VG 10, Ladybug H1, Dragonfly 2 in ZDP 189 and Superblue/420J1 and H1, Delica in ZDP 189, Clipitool Standard, the Cook’s knife VG10, Santoku, paring and utility knives, all in MBS 26. :spyder:
Rp5
#48
Post by Rp5 »
Bolster wrote:
Fri Jun 04, 2021 6:31 pm
Does anyone know if Larrin has this graphic (one of the most important, IMO) with labels on all the datapoints? There is sort of a tightly clustered "stainless steel winner's circle" for a well-balanced steel around SPY27 and XHP but I'd like to know what the other near datapoints are. Possibly S35VN, S45VN? Dunno.
I'm sure that Larrin does, but he hasn't posted it that I've seen. I've been trying to compile a list of his data points though, and my running list is pictured below. The difficult part, as I'm sure you know, is that Toughness and Edge Retention are inversely related to hardness, so testing steels at different hardness can produce different results. Hard to plot data points on a sliding scale. These are my best approximations. I think Larrin appreciates toughness because as he always points out, edge geometry matters more than composition, but when you have higher toughness in your composition, you can heat treat harder and make thinner blade stock with less probability of chipping or breaking than a lower-toughness steel.
As to the thread - as others have said, my top three lookouts are MagnaCut, Vanax, and Non-Steel (Elastic Ceramic/Tungsten Carb/Dendritic Cobalt.)
Josh Crutchley
#49
Post by Josh Crutchley »
I would really like to see something like Vancron, Vanax, or something similar with carbonitrides might be interesting.
AlexRus
#50
Post by AlexRus »
Joshcrutchley1 wrote:
Mon Jul 05, 2021 7:14 pm
Some stainless monsters? :)
DansGearAddiction
#51
Post by DansGearAddiction »
Magnacut, S390, M398 or REX121 would all be sweet.
Current Collection
Chaparral (LW, Stepped, Stealth, Sun & Moon), Dragonfly 2 (VG-10), McBee, Stretch 2 (K390), UKPK Salt (LC200N)
Fireman
#52
Post by Fireman »
I’m stuffing the ballot box…
S7!
3V!
52100!
Dendritic cobalt would be rad. I have a knife already in it by Boye but I would buy a mule version. Cast mule would be a first but not the first cast knife for Spyderco.
:winking-tongue Mule Team Army 001
MNOSD 008 :usflag
Image Stable Mules; Z-Max, Z-Wear, Magna Cut, SRS13, Rex 76, Rex T15.
KnifeKnuts
Location: Kitsap Peninsula, Puget Sound, Washington, USA, Earth
#53
Post by KnifeKnuts »
Manganese wear plate Mule Team blade.
AlexRus
#54
Post by AlexRus »
Fireman wrote:
Fri Jul 23, 2021 9:52 pm
S7!
3V!
52100!
52100 was the first Mule to be released back in 2007 :)
Fireman
#55
Post by Fireman »
AlexRus wrote:
Fri Jul 23, 2021 11:46 pm
S7!
3V!
52100!
Thanks. I was uncertain of that one but did not look at the list before posting. Thanks for the correction.
MNOSD 008 :usflag
AlexRus
#56
Post by AlexRus »
Fireman wrote:
Sat Jul 24, 2021 7:16 am
S7!
3V!
52100!
Sometimes you may still see one of them 52100 for sale :)
cody6268
#57
Post by cody6268 »
I was just looking at a Crucible spec sheet for CPM-20CV which mentioned a CPM-9V, said to be extremely tough and wear-resistant, and I wonder if it would be actually usable as a blade steel?
Fireman
#58
Post by Fireman »
AlexRus wrote:
Sat Jul 24, 2021 8:22 am
S7!
3V!
52100!
I think my brain might have meant 5160. All the super tough steels. A millie in super tough steels appeals to me and especially one in LC200N
MNOSD 008 :usflag
AlexRus
#59
Post by AlexRus »
I'm for MagnaCut and M398 :cheap-sunglasses
Tucson Tom
#60
Post by Tucson Tom »
Not that I expect this to happen, but I sure would like to get a mule in 52100 -- but this would be a replay of a mule from before my time. I just wish I had a mule sized fixed blade in 52100, that would make me happy.
But among the choices in the short poll, I would pick the Vanax.
