Spyderco's ATS-55 Era: A Really Noteworthy Time In Spyderco History
Re: Spyderco's ATS-55 Era: A Really Noteworthy Time In Spyderco History
#41
Post by JD Spydo »
Sumdumguy wrote:
Fri Aug 21, 2020 8:33 pm
I had a CE Tanto folder in ATS-55 and it had some mean, nasty serrations. I would have no problems using it again.
I bet I've got the same one you do>> because I still have a C-46 Lum Tanto CE folder ( coated blade). Yeah mine is an ATS-55 as well.
It does seem like Spyderco did make several of their models in combo edge back in those days. I even used to have a combo edged Military model from that time as well.
I know what you mean by "nasty serrations" on that unit because mine are like wicked needles on that model.
Sumdumguy
#42
Post by Sumdumguy »
JD Spydo wrote:
Sat Aug 22, 2020 5:22 am
That's the one. I ended up selling it, which I regret. But, yes, the serrations were vicious. Had to be mindful of them, as they would reach out and grab you before you realized it.
-Thomas Jefferson
#43
Post by JD Spydo »
Sumdumguy wrote:
Sat Aug 22, 2020 5:26 am
That's interesting that you bring up the serrated CE part of the C-46 Lum Tanto like I said mine are like wicked needles instead of the spike & scallop type serration pattern. I would sure hate to get raked by those nasty serrations.
I always love the handle on that C-46 Lum Tanto folder out of the ATS-55 era. That model totally changed my attitude about tanto blades. But Bob Lum's were a different animal all together. It's so sad that that man died when he did. I was about to have him make me a custom Tanto folder when it happened.
Sumdumguy
#44
Post by Sumdumguy »
JD Spydo wrote:
Sat Aug 22, 2020 5:34 am
I agree 100%. The handle on the C46 is one of my all time favorites.
As for Lum, he is the only designer of modern tanto blades that I really like, they feel special. Whereas most of the other ones are just "tacticool" fodder.
Truly a great loss.
-Thomas Jefferson
#45
Post by JD Spydo »
That Lum C-46 Tanto folder wasn't the only folder out of the ATS-55 era that had a great handle. The Stainless RESCUE model that I brag about a lot has the best overall grip of any of the stainless, sheepsfoot models. Also the Peter Herbst model out of that era also had a really nicely made handle too.
Also the handles on the C-42 Viele, C-48 Wegner along with the C-50 Centofante also had great, well designed handles from that era. Also the GODDARD models seem to have a great handle as well. The ATS-55 era was a turning point for the company in so many ways. Because design ergonomics really rapidly improved during that time.
James Y
#46
Post by James Y »
For some reason, ATS-55 never “grabbed” me like it should have. When VG-10 took over, I liked it better. I have several knives in ATS-55 and they are great. I don’t really know why I didn’t like it more.
#47
Post by JD Spydo »
James Y wrote:
Sat Aug 22, 2020 8:06 am
Yeah Sal told me once that when they tested VG-10 along side of ATS-55 they never looked back after that. I do believe that over time most of the ATS-55 models that are still NIB will bring big values.
It's a shame you don't really like ATS-55 because for some strange reason because I've had really good luck with all my ATS-55 models. Especially the Spyderedged models. And it's just not too shabby in PE either. But it kind of depends on the blade designs. Take the plain edged blade from the original C-44 Dyad>> I can get that blade so sharp that I even cut up pork tenderloins with it like I'm using a laser. I never got rid of most of my ATS-55 models>> I'm sure sentimental reasons are at play because I dearly love the older Spyderco models so much. But to me performance wise I like the ATS-55 about as good as I do the VG-10. Actually I'm kind of fan of both steels even with all the newer supersteels available.
James Y
#48
Post by James Y »
JD Spydo wrote:
Sat Aug 22, 2020 2:31 pm
Joe,
I guess I didn’t actively DISlike ATS-55, I just didn’t care for it like I thought I would when it first came out. I still have all my knives I bought in that steel. One thing that annoyed me about it was that I’d get rust spots forming on it just from being clipped in my pocket in a single day. It was easy enough to get off with 0000 steel wool and mineral oil, but it happened with several of my ATS-55 blades, and multiple times with each blade. And my perspiration is not particularly acidic; certainly not as much as many other guys. I know there are many here for whom good corrosion resistance is not high up on their list of important qualities in a steel, but it is for me, at least when it comes to folders.
#49
Post by JD Spydo »
Yeah I've had some corrosion issues with a couple of my ATS-55 blades as well. But over the years I've become a firm believer in Marine Grade TUF CLOTH made by Sentry Solutions company. It gives you just enough protective coating to prevent most rust or corrosion. Unless I'm using a blade for food processing>> then I don't put anything on them.
What I like about ATS-55 the most is that I've found it to be one of the better blade steels for serrated/Spyderedges. I put it right up with VG-10 and AUS-8 both on serrated edge performance. And it's not a monster to sharpen like 440V is. Jim I get what you're saying because I never could fully ever warm up to Spyderco's GIN-1. It wasn't bad in SE but in plain edge I was spending way too much time sharpening it. It was almost a daily job just keeping it sharp enough to do daily jobs. There are a couple of GIN-1 SE models that I would still use in a pinch but I would never again use GIN-1 for a plain edged blade with all the good stuff we have to choose from now a days.
My obsession is probably linked to my fervent love of the models in what I call The GOLDEN ERA OF SPYDERS 1998-2004. And the ATS-55 models fall right into that era. But it's all good and we all like different knives and different blade steels for a variety of reasons. Let's put it this way>> Spyderco's worst or lowest rated is head and shoulders above most company's premium models. Case Closed :cool:
#50
Post by JD Spydo »
Sumdumguy wrote:
Sat Aug 22, 2020 5:42 am
Glad you brought up handles because I'm going to focus on the handles in the ATS-55 era. Because after reading your post I got my 1999 Spyderco catalog out and looked through the entire ATS-55 line up. And you're most definitely on to something significant because that entire ATS-55 line up is stacked with great models that have really nice handles.
A few to consider are the C-46 Lum Tanto as you pointed out. The Big Calypso C-54 model ( superb Micarta Handle), The original Caly Jr models, The Peter Herbst, The Goddard models, The Pro-Venator, The first G-10 Police models, The Rookie, The Big Dyad C-44, The G-10 Harpy, and the AUS-8 Catcherman.
There most certainly was a shift or even a total product evolution in the handles on newer models in the ATS-55 era and the other models which got revamped and upgraded during that time slot. Yeah it's fair to say that the ATS-55 era took a huge step up the "quality ladder" with several of the models in that era. Oh and did I mention the first Jot Singh Khalsa model?? as well as the C-42 Howard Viele model. Yeah the company took a huge step up The Quality Ladder during the ATS-55 era.
