hardest use spydie folder?
- chuck_roxas45
My spin on this.
The D'Allara Full Serrated (its the one I have). Solid chunky blade, big chunky handle, solid lock-up.
Twist and turn the blade when dug into something and it will not budge.
http://www.spydiewiki.com/
- chuck_roxas45
Chuck,
It's really a shame about your fixed-blade ban; but in the future, if that gets fixed, you simply MUST get a Rock Salt! That is THE knife for your use/environment.
Where are you that has such primative environment yet restrictive knife laws?
Otherwise, until then, get yourself a pair of Pacific Salts (one PE one SE). They are hella tuff and the blade only gets better with use/sharpening. I did some boonie busting on Guam for a couple of years and could really have used some good H1 knives then! But a good machete is still the tool of choice.
How can you live in the jungle without one? :o
Good luck to ya! I really loved island living! :cool: :D
Hafa adai!
hickster
Hafa adai!
hickster
I think that the Gayle Bradley is the toughest folder I have seen. I just can't imagine what you would have to do to defeat it.
Regards, Al
The "soul" of hi-tech materials like G-10, H1, ZDP, Titanium, carbon fiber, etc is found in the performance. That appreciation of the "spirit" comes out in time, after use. It's saying, you can depend on me! I'm there for you no matter what! - Sal Glesser
- chuck_roxas45
- chuck_roxas45
i am a commercial builder. my knives are used for scraping, prying, cutting (drywall, carpet, linoleum, tubing, FRP, etc.) deburring copper, etc.chuck_roxas45 wrote:that's not saying anything. maybe abuse for you is light use for me or vice versa. what were you doing with them when their tips broke off?
the tip on the Millie broke when i was demo-ing a restaurant in Austin. we were removing an 8x12 walkin freezer that had been completely sealed with silicone. my Millie was the only knife that could cut deep enough to separate the panels. 2+ hours of cutting silicone sealant and i broke the tip.
the Manix2 (154 CM) was broken lining up two pieces of 16 gauge stainless steel at 90 degrees that i was welding. the corners had been tacked and the center was sagging.
sorry i wasn't more specific as to the details of the failure(s). i was simply giving my opinion that the Chinook is a beast and could take the beating that i dish out.
- chuck_roxas45
- chuck_roxas45
Of the current folders, I would also vote for the Chinook 3.
It's hard to define the "best" because the task at hand is different. The best at batoning, the best at edge holding, the best confident grip which translates into cutting power?
If you are assuming gloved hands for heavy duty work, I would go for the one that provides comfortable ergonomics and an amazing steel. Bonus points for obtuse ground tips (Tanto) or at least wide ones where you can use more belly (Chinook vs Military).
Steel wise S30v would not be my pick. The abuse you would have to put M4 through to see a chip the S30v would be waving a white flag and trying to call in a rescue chopper.
That said, the style and use that Grunt0331 put his Chinook3 through is VERY impressive. Gotta love 4mm thick blades and a good belly :)
peacefulNeasyfeelin
Hmmm........ in UK, it is not matter whether they are folders or fixed blades being illegal or legal - but it is the length of blades - anything over 3 inches would be (be it folder or fixed) illegal to carry in public.The Deacon wrote:Yes and no. A well made fixed blade can take more abuse that a folder, but they are less convenient to carry and, in some areas, restricted or prohibited. Note the OP's comment in post #21 that "A fixed blade would be ideal but is not a legal option at the moment."
And any gravity operated or disguised blades being illegal regadlress of any other criteria - more of the folders would fall into illegal category.
