Are you saying that most tangs on these thicker bladed knives are equal to (about) the cross sectional area of steel located on one side or the other (not both) of that hole?yablanowitz wrote:"..Stacked leather washer handles are usually mounted on a stick tang, and the normal stick tang has about half the cross-sectional area of the Bushcraft at the point where that one broke.."
Bushcraft UK - 2nds "heads-up"
yablanowitz
Yes, I am. Years ago I dismantled a Navy MK2 (what most folks call a KaBar, regardless of maker) and was somewhat surprised to find the tang of the knife was only about 3/8" wide. It was not some cheap imitation either, I bought it through the Navy supply system. A couple of others I've checked were made the same way, and inquiries indicate it is standard construction.RzrSxS wrote:Are you saying that most tangs on these thicker bladed knives are equal to (about) the cross sectional area of steel located on one side or the other (not both) of that hole?
That is for stacked leather handles. Someone here has posted x-ray pictures of both the Spyderco Temperance and a Mora (popular low-cost bushcrafting knife) showing the partial stick tangs. That means not only is the blade tang not the full width of the handle, it doesn't run the full length either. If you can see the tang between the scales (full width tang) and the knife doesn't feel horribly butt heavy in hand, there are probably holes under the scales to balance the knife.
- RamDreamer
Not very many left...
Just a note to advise that there are not very many of these Bushcraft knives left.
I went to the SFO today and picked up a couple. :D
They are absolutely beautiful. But there are very, very few of them left. So if you want one, pull the trigger right away.
A batoning video on Youtube of the Bushcraft:
http://www.youtube.com/watch?v=bp3bcCd46kA
Looks like he spent hours splitting wood, lol. Great real test though!
- JediKnight86
Too risky to try stabilized wood again? I think a micarta like on the Temperance 2 would be better than G-10, but that's just me.sal wrote:We'll be getting the knife back. We'll analyze the problem and make the necessary adjustments for the next run of the Bushcraft UK model. More than likely with a G-10 scale. It's the "real world" testing that molds the designs of the future.
Anyway...
Got mine today! Big crack in the handle, but beautiful wood anyway. I really don't like the chip in the spine that indicates it as a 2nd. This one is definitely a user.
If I buy one from another retailer that isn't a 2nd is it likely to crack or is it stabilized and under warranty?
Hi my name is Alex and I'm a Spyderholic :D
chas brookes
Bushcrafter Matching Firesteel and replacement sheath
Hi all
I was lucky enough to have a piece of wood kicking around that seemed to match the spalting on the Bushcrafter so I made myself a matching firesteel. I also had a leather sheath for a Mora which I had not been using with some minor mods and a bit of renovation it seems to be a nice fit for the Bushcrafter :)
HistoricalMan
That setup looks wonderful; almost as if it came from Spyderco like that.chas brookes wrote:Hi all
Good job!
