Exactly what's probably going to happen when mine arrives. Immediate teardown, clean, lube, and adjustment. Ive had a couple Spydercos come bone dry (like my Native Chief) so getting in there and making sure it is lubricated is a big thing for me!TkoK83Spy wrote: ↑Fri Mar 05, 2021 12:21 pmOr be impatient like myself and immediately tweak the pivot :pDanvp wrote: ↑Fri Mar 05, 2021 12:10 pmvisionloss wrote: ↑Fri Mar 05, 2021 10:41 amI'm glad to hear several others complaining about action grit/scratchy/screach issues. I'm dissapointed with my z-wear. It just doesn't feel anywhere near as smooth as my stock g10 model. QC should have noticed the poor action if they opened/closed it even a couple times. Unless this falls within their allowable range, which I can't imagine because all my other spydercos are super smooth. For this reason it is probably my least favorite out of my collection. Pretty dissapointing lack of quality for a really hyped sprint. I hope this isn't the direction spyderco is headed.
It will break in with use. Give it some time...
Shaman Z-Wear Sprint - General Discussion & Support thread - (not alerts)
Re: Shaman Z-Wear Sprint - General Discussion & Support thread - (not alerts)
Henry_P wrote: ↑Fri Mar 05, 2021 1:36 pm
Ya I have noticed my shaman has already broken in some and is less scratchy then when I first unboxed it. I feel like whatever was causing the scratching is finally getting worn down. What is strange is that my blade centering seems to be correcting itself over time.
Blade centering is easy to fix. Look at which side the point favours when the knife is closed. If it is favoring the lock side, open it, put your left thumb on the pivot and pull the end of the blade towards you with your right hand. Works on PM2’s (had to fix multiple) and is not my idea. Learned it on YouTube. My shaman is dead center btw
Got mine just a few minutes ago, courtesy of TkoK83Spy! Mines pretty much good to go, little blade play (easy to fix), slightly off center (also easy to fix). Great action.
One observation I made: the Shaman has THE most aggressive blade spine jimping of all Spydies I've handled yet. It's almost as if it could be used as a file! Is it just this Z-Wear version? Or are jimpings on all Shamans like that? Jimping on my N5 is way more skin-friendly.
Another observation: the Shaman is the first compression lock that pinches me a little when I grab the knife real tight. Must be related to the very heavily shaped ergonomic scales. Every aspect has its pros and cons...
I've broken it in a good part now, and have compared it with my N5 G-10 extensively. They ARE brothers, without a doubt! :) Stating the obvious, I know...
Michael
- steelcity16
archangel wrote: ↑Sun Mar 07, 2021 12:19 amOne observation I made: the Shaman has THE most aggressive blade spine jimping of all Spydies I've handled yet. It's almost as if it could be used as a file! Is it just this Z-Wear version? Or are jimpings on all Shamans like that? Jimping on my N5 is way more skin-friendly.
I've broken it in a good part now, and have compared it with my N5 G-10 extensively. They ARE brothers, without a doubt! :) Stating the obvious, I know...![]()
The jimping on mine seems in line with the rest of the Golden models I compared to (Manix XL, Manix, PM2, and Para 3). I'm a jimping fanatic so as long as it isn't shredding my thumb to the point of drawing blood I'm good! I would say the Golden jimping is more aggressive than the Seki jimping for sure though!
My S30v shaman is pretty tame. That's due to the stonewash on the blade. The zwear is satin, so it feels sharper. Same with my m4. Feels similar to my other golden knives with satin or dlc finishes.archangel wrote: ↑Sun Mar 07, 2021 12:19 amOne observation I made: the Shaman has THE most aggressive blade spine jimping of all Spydies I've handled yet. It's almost as if it could be used as a file! Is it just this Z-Wear version? Or are jimpings on all Shamans like that? Jimping on my N5 is way more skin-friendly.
Update on my zwear though. I disassembled, cleaned, and lubed it. It's as close to perfect as I can see. Very little loctite on the pivot and it was loosening, so that explains the blade play. I got it back together, took off the clip and left all screws loose. Put the blade at 90 degrees and tightened down the pivot and tightened all the scale screws, then adjusted the pivot for no play and good action. Not completely free swinging, but I can flick it closed no problem.
Reattached the clip, and the knife is almost perfectly centered. It's a hair off to the show side. I could probably get it perfect but it's fine for me, and I'll be using it so I'm not going to stress over it.
Now to look ahead at what configuration the Shaman will be in next!
Just received mine, thank you heaps to the person who helped me out!! This thing is burly! Makes the Military seem... not quite delicate, but you know? Smaller. The other thing I noticed right away is that I haven’t carried a comp lock in long enough that I’m reaching for the liner lock to close the Shaman.
- RAHComanche
Did we ever get a notification of shipping to dealers for the Shaman like we got for the Salt 2 Green LC200N, Dragonfly 2 Pink S30v FRN, Police 4 LW K390, Delica 4 Pink/Black, Manbug Wharncliffe, etc, etc, etc
Why the exception? And is Bladegq going to release their bounty? Why the delay? The irony is that to buy the knife we have to work for a living which means we cannot hit F5 refresh all the time during the work week!
The notifications are only for regular production models, it seems. Not sprints or exclusives.RAHComanche wrote: ↑Thu Mar 11, 2021 9:02 amDid we ever get a notification of shipping to dealers for the Shaman like we got for the Salt 2 Green LC200N, Dragonfly 2 Pink S30v FRN, Police 4 LW K390, Delica 4 Pink/Black, Manbug Wharncliffe, etc, etc, etc
- Julia
So the slow trickle continues, no idea of the logistics involved in creating, manufacturing and delivering these knives but if I read the date code correctly mine was born August, 2020
I think I'd grab another one if I can be on time for the Blade HQ release
PM 2 Böhler M390 * PM 2 CPM 20CV * PM 2 CTS 204P * PM 2 CTS Maxamet * Yojimbo CPM M4
Shaman Zapp Z-Wear PM * Spydie Chef Zapp LC200N * Techno 2 CTS XHP * Drunken CPM S90V
Benchmade Griptilian 20CV * Mini Grip S30V * Kershaw Launch 1 CPM 154 * Kershaw Link S35VN
Gerber Applegate Fairbairn Covert ATS 34 * KaBar 1211 AISI 1095 * Cold Steel CS-13QMBIX CPM 3V
PD1 Shaman with brown micarta handles, anyone?sal wrote: ↑Fri Mar 12, 2021 12:26 pm
Sorry for the frustrations. I believe part of the issue is the recent increase in demand for Spyderco products. Most of these projects are started a year or two before they are released so quantities are "guessed" base on current demand at the time the project begins. We'll have to be more creative.
Maybe with a bump up to 6,000 pcs they may stay in stock for a full 5 minutes :D
- steelcity16
Zive wrote: ↑Fri Mar 12, 2021 1:00 pmPD1 Shaman with brown micarta handles, anyone?sal wrote: ↑Fri Mar 12, 2021 12:26 pm
Nah, 3,600 is plenty between the two releases. They are selling on the bay now for $299.99, and I've seen a few on BF for S275, which isn't really too much of a markup, so it looks like *most* of the true (non-flipper) end user demand was met with this run where people aren't willing to pay $350, $400, or more like with the first run.
Time to move on to bigger and better things. Other models (Manix XL, Military, Endura, Endela), other steels like K390, AEB-L, and 3V, other colors like OD Green Micarta, Black Micarta, and Denim Micarta. The Micarta show is just beginning, let's not get too wrapped up in this single model/steel/color (I know, easy for me to say since I got one
I completely agree, and was more so lamenting that even when Sal goes out of his way to please the community it never seems to be “enough”.
Would also prefer to see more attention/cru-carta treatment spent on other models.
I agree too. It is impossible to please everyone, that happens with every sprint run. I think they should spend their time creating other models not another micarta shaman.
Para 3 Maxamet | Para 3 CruWear DLC | Smock M4 Jade G-10 | Shaman Z-Wear Micarta | Salt 2 LC200N Wharnie | Chaparral Birdseye Maple | Lil’ Native S90V CF | Dragonfly 2 20CV | Ladybug K390 | CRK Small Sebenza 31 S45VN PJ
I'm interest in both more micarta shamans but also cru-carta manix 2/manix 2 xl please :)
31 Spydercos | 21 Models | 19 Steels
My Shaman was very smooth straight out of the box. After a week though it started to screech and jam. Now I can’t flick it open. Tried the compressor and blew some air through it to no avail. Now I need to find some tools and buy oil and take it apart. Not the biggest of deals but a bit disappointing nevertheless, considering it’s a +$300 knife (in Europe).
Mine was pretty stiff, it’s loosening up. I’ll probably dismantle soon to grease the pivot and just cause I like to.
The only thing I've noticed on mine is that when I press the lock lever to close the blade the ball bearing makes a grindy sound as it slides along the tang of the blade. If I press the lock lever in all the way, it's silent. I'm not used to the slightly stronger lock lever; it's me, not the knife.
- VooDooChild
It just needs a drop of oil. You dont need to disassemble it. Standard maintenance issue. Probably didnt get enough oil at the factory.Eratus wrote: My Shaman was very smooth straight out of the box. After a week though it started to screech and jam. Now I can’t flick it open. Tried the compressor and blew some air through it to no avail. Now I need to find some tools and buy oil and take it apart. Not the biggest of deals but a bit disappointing nevertheless, considering it’s a +$300 knife (in Europe).
Replacement MXG deep pocket carry clip, now at the right end of the handle (I prefer tip down carry on all my Spydies, where it is possible). NOW my Shaman is perfect! :)
MXG clip came with two replacement screws, but I couldn't use those cause when they were screwed in all the way, they locked the blade. I'll never understand how manufacturers of product specific add-ons can't actually make them right... oh well, no problem here since the factory screws had the right length.
Michael
