River's Edge Exclusive
- dull&blunt
Re: River's Edge Exclusive
I’ll probably bite on one of these. Probably going with DLC because my other Para 3 is a satin Rex 45. But then again, a nice patina is cool.
So, newb question. What's the attraction of 10V? Is it Florida humidity approved? Thx...
- Richard
- Traditional.Sharpening
Define approved? Will it rust to oblivion? Likely not. Will it corrode over time. Likely yes depending on how you live, indoors in A/C or full time outside. DLC would help but probably not completely. I'd say Magnacut is a much better choice or something Stainless. Alternative would be to disassemble and treat all metal parts with a few coats of Eezox allowing it to dry/evaporate between coats. This is actually pretty amazing and almost negates the need for stainless steel in most applications.
Thanks for the response and recommendation! I've been checking out this video by Knife Steel Nerds comparing 10V and K390. A lot of it's over my head, but still pretty enjoyable.Traditional.Sharpening wrote: ↑Wed May 31, 2023 3:52 pmDefine approved? Will it rust to oblivion? Likely not. Will it corrode over time. Likely yes depending on how you live, indoors in A/C or full time outside. DLC would help but probably not completely. I'd say Magnacut is a much better choice or something Stainless. Alternative would be to disassemble and treat all metal parts with a few coats of Eezox allowing it to dry/evaporate between coats. This is actually pretty amazing and almost negates the need for stainless steel in most applications.
- Richard
- kennethsime
To be fair, I haven’t watched their channel for a few months, but my experience is that it’s kind of like the blind leading the blind. For similar channels, from similar businesses, David C. Andersen at Knife Center and the new guy at BHQ both seem to be much more well-informed.Larrin wrote: ↑Wed May 31, 2023 5:11 amI haven’t been watching. What is so bad about their YouTube?kennethsime wrote: ↑Wed May 31, 2023 1:03 amEhhhhi I liked the green ones, but then so did everyone else. I don’t much care for their YouTube presence. I’m good on this one.
Anecdote time: when I was selling knives, I took pride in getting to know my product. When I started out, I kind of knew that 440C was good, and that knives made overseas tended to be lower quality, and that was about it. During my two years at the knife store, I learned about particle metallurgy (admittedly, not to the same extent as some of us
Now, I’m not saying the REC guys don’t take pride in their YouTube work - but I don’t see it, where I do with their competitors.
There’s also some weird drama about the owners and a certain minor YouTube celebrity. I won’t elaborate on that one.
Anyway, back on topic: I hope folks enjoy this knife. I sure enjoy my K390 Para 3.
I actually see little reason to go for this unless you just like the design and color. To me I'd rather have 2 of the Para 3 LW in BD1N than this one even though I like the color. There's just not as big a difference in steel performance in real life that you will actually be able to distinguish and anything you may could easily be a product of other influences (sharpening, cutting materials, technique, geometry at the edge). BD1N is a very solid choice for the money and I would like it to become more of a fixture as it's very well rounded. SPY27 may also be a good choice there but I've no experience with it.riclaw wrote: ↑Wed May 31, 2023 7:41 pmThanks for the response and recommendation! I've been checking out this video by Knife Steel Nerds comparing 10V and K390. A lot of it's over my head, but still pretty enjoyable.Traditional.Sharpening wrote: ↑Wed May 31, 2023 3:52 pmDefine approved? Will it rust to oblivion? Likely not. Will it corrode over time. Likely yes depending on how you live, indoors in A/C or full time outside. DLC would help but probably not completely. I'd say Magnacut is a much better choice or something Stainless. Alternative would be to disassemble and treat all metal parts with a few coats of Eezox allowing it to dry/evaporate between coats. This is actually pretty amazing and almost negates the need for stainless steel in most applications.
- dull&blunt
Traditional.Sharpening makes some good points. But it should be mentioned that 10V is a well rounded steel when corrosion resistance is not a huge issue. Plus it's been awhile since Spyderco produced any 10V models. Decent impact resistance, great edge retention, and high hardness are attributes which grab a steel nerd's attention, and 10V has all of those. But you can find those same attributes in other Spyderco regular production steels like K390, Cru-wear, or M4. So this is not a 'must have' knife, but I'm sure you can understand why some people might be excited. And I will say this: I doubt you would regret buying one if you're looking to buy a new knife (assuming you like the Para 3). The DLC coating will help with corrosion issues as long as you clean it after use.riclaw wrote: ↑Wed May 31, 2023 7:41 pmThanks for the response and recommendation! I've been checking out this video by Knife Steel Nerds comparing 10V and K390. A lot of it's over my head, but still pretty enjoyable.Traditional.Sharpening wrote: ↑Wed May 31, 2023 3:52 pmDefine approved? Will it rust to oblivion? Likely not. Will it corrode over time. Likely yes depending on how you live, indoors in A/C or full time outside. DLC would help but probably not completely. I'd say Magnacut is a much better choice or something Stainless. Alternative would be to disassemble and treat all metal parts with a few coats of Eezox allowing it to dry/evaporate between coats. This is actually pretty amazing and almost negates the need for stainless steel in most applications.
K390 is one of the steels that Spyderco introduced to the production knife industry. From the first time I saw the chemistry, we had to; convince the foundry to make some for us, make a Mule and test it, get more made, work with some of our off shore makers to learn how to work with it, bring it into the market. The rest is history, but the initial effort took years. We are appreciative to all involved to be able to bring this to you, and we especially appreciate Larrin who brings us easy to understand information that we steel junky's seek.
- WilliamMunny
It’s one of the things that makes Spyderco special,, always looking for and pushing the limit of steel. Plus amazing customer service…. I for one and very excited for this PM3 in 10V. I am just going to hold out for a satin ones, with any luck I can get one when ever they put them up for sale.
We know you want one of these with a satin finish, you've mentioned it 3 times in this thread already
~Joe
MNOSD member #0045
~Joe
MNOSD member #0045
- WilliamMunny
That’s funny, I did not realize it, sorry. Guess I am just excited about this one.
- Manixguy@1994
I say go for it , and enjoy . Let us us know your opinion and pics after you have had it for a while . Lot’s of opinions, but at the end of the day it’s what you want that matters . If it had been a Manix model I would have jumped on the DLC . MG2WilliamMunny wrote: ↑Thu Jun 01, 2023 7:06 pmIt’s one of the things that makes Spyderco special,, always looking for and pushing the limit of steel. Plus amazing customer service…. I for one and very excited for this PM3 in 10V. I am just going to hold out for a satin ones, with any luck I can get one when ever they put them up for sale.
WilliamMunny wrote: ↑Thu Jun 01, 2023 9:15 pmThat’s funny, I did not realize it, sorry. Guess I am just excited about this one.
Don’t be sorry! It’s just funny is all
~Joe
MNOSD member #0045
~Joe
MNOSD member #0045
Kind of silly to see these going for $250-300 over on the Knife Exchange for those who snagged one (or more?) at Blade Show
. Looks like the satin one (which I believe was listed at $250) has sold.
Never had, nor held a Para 3, but this one has me most tempted. I'll be awaiting the satin drop (and pricing) to see if that temptation is worth the reservation of funds.
Make Knife Grinds Thin Again.
Hehehehe........ 🕷 🕸 🕷 🕸 🕷 🕸 🕷 🕸
Ya gotta
it!!
Ya gotta
MacLaren wrote: ↑Mon Jun 05, 2023 7:38 pmHehehehe........ 🕷 🕸 🕷 🕸 🕷 🕸 🕷 🕸
Ya gottait!!
https://i.postimg.cc/cLqCyLTw/Screensho ... cebook.jpg
Last weekend, I picked up the DLC para3 at blade show. I have a couple of knives from another maker with 10v, I'm excited to try this steel in a Spyderco model. Independent of comparisons based on edge retention or toughness, I've found this steel to be straight forward to sharpen and easy to maintain at a keen edge. Plus, I like the color scheme.
Dear kerkit11:
Stay safe,
Mike
Stay safe,
Mike
Wow, 10 minutes later and the knife is still available. Must have had quite a stock with this exclusive.
