What kind of Loctite do you use vivi?
Anyone tried this?
Re: Anyone tried this?
1 Byrd and 30 “others”
You'll be fine with that, BT. It's not rocket surgery. Cleanliness is kind of important, though. On small fasteners, sometimes it's helpful to use a toothpick to apply the Loctite to the threads. Keep in mind of what happens if you use to much. On the female threads, you'll be pushing Loctite down the hole. On male threads, excess Loctite can puddle up around the head of the fastener. The downside of all this is that you don't want excess going where you don't want it, specifically, into the pivot.BLUETYPEII wrote: ↑Sun Oct 18, 2020 9:59 amThanks for the info everyone. I suppose I’m going to go ahead and use the blue Loctite. If anyone else thinks this is a bad idea please chime in before I mess something up. :eek:
You are exactly right about putting too much Loctite on the pivot. Whoever originally assembled my Spyderco Siren put a bit too much on and it was not allowing the blade to drop shut. Pulled the pivot screws out and they were slathered in it so I cleaned them up and put it back together and it was smooth as silk I’m just looking to make sure they don’t back out on their own and get lost.RustyIron wrote: ↑Sun Oct 18, 2020 11:01 amYou'll be fine with that, BT. It's not rocket surgery. Cleanliness is kind of important, though. On small fasteners, sometimes it's helpful to use a toothpick to apply the Loctite to the threads. Keep in mind of what happens if you use to much. On the female threads, you'll be pushing Loctite down the hole. On male threads, excess Loctite can puddle up around the head of the fastener. The downside of all this is that you don't want excess going where you don't want it, specifically, into the pivot.BLUETYPEII wrote: ↑Sun Oct 18, 2020 9:59 amThanks for the info everyone. I suppose I’m going to go ahead and use the blue Loctite. If anyone else thinks this is a bad idea please chime in before I mess something up. :eek:
When I use Loctite, I only use a minimal amount, but enough to get into the threads of the screw. If I put a little too much on the screw, I touch it to a small bit of tissue paper to absorb away the extra Loctite before putting the screw back in.
Working great so far, you have to leave it on the threads for about 20 minutes to kick before putting the screws back in but screws definitely secure now Will update after a few weeks of carry.
Just don't use a lot. You really only need a small dab, and let it sit for about 24 hours after you adjust your pivot.BLUETYPEII wrote: ↑Sun Oct 18, 2020 9:59 amThanks for the info everyone. I suppose I’m going to go ahead and use the blue Loctite. If anyone else thinks this is a bad idea please chime in before I mess something up. :eek:
Spyderco : Resilience, Tenacious, Persistence, Manix 2 G10, Para 3 G10, Para 3 LW, Paramilitary 2,
You’re most welcome, Blue.
My attitude towards such things is; if you can hold something in place securely with a thumb tack, a four inch nail is most likely overkill. :)
Tell that to Edward Scissor Hands.....
