Yeah, for a bad cut like the OP it's just a stop gap until you get to a doctor. There's also a pharmaceutical grade superglue called Dermabond that also contains an antibacterial. You can find a tube on amazon for like 20 bucks.
Really bad cut.
Re: Really bad cut.
Re: Really bad cut.
I've been stabbed in the hand twice. I do not recommend it. I cut the tip off of my middle finger fixing dinner for a group of green berets. I have cut my middle finger at the proximal joint down to the bone with a linoleum carving knife, and I have had more cuts than I can remember. If it is bad, it is best to get it checked out by a doctor.
Re: Really bad cut.
Before I cut my self, I used antibacterial soap that was at the kitchen sink to wash some random cutting debris off my knife blade, I had washed my hands as well.
Then I went to Lowe’s and sliced my self, the blade was clean, my hands were clean. Especially since it is on the top of my finger.
I did not wash the cut, I wouldn’t use alcohol, or peroxide. Knowing those things can damage tissue. It was a clean cut, and luckily a clean blade just by chance!
So I crazy glued it shut, I sealed it and nothing can get in. I checked it this morning, after a bandaid change. And it is sealed shut, even while bending my finger. It doesn’t hurt, only if I reach to grab something that low down, then blood starts to pump you can feel a slight discomfort only briefly.
So, I think I’m ok. And I feel confident it will heal perfectly.
“My daily razor blade”
^Wicked Edge guided system^
Re: Really bad cut.
My wife cut her finger tip off with one of the Spyderco kitchen knives. I've been lucky. I was cutting something and the knife slipped and cut right through my jeans in the crotch. Luckily it didn't hit the artery in my leg or other things that are close. I didn't even feel it cut the fabric just glided right through.
Re: Really bad cut.
Hope you heal up quick and with no problems. Small comfort, but at least you can say you weren't being careless. An oddball accident like that could happen to anyone.
Re: Really bad cut.
happens often to me. :o
Most times I glue it closed and it's fine, but sometimes you know you gotta get stitches,
and I recommend getting them in those cases, the other option is often longer, more painful, more expensive and not worth it
My last cut in May 2018 was one of those instances:
heal fast and well!! :spyder:
► Show Spoiler
Re: Really bad cut.
The problem I’ve had with CA glue is it doesn’t hold long enough. For deep cuts you need something that will maintain pressure for several days, and glue peels off soon because the skin lets go. I’ve made do by re-gluing as I noticed it failing.
For a back of the finger cut, I dunno, I would probably see how it goes with glue. Now that I have kids I stock steri strips which can help in a pinch too. If it were a cut to the bone on the underside of the finger I think a trip to urgent care is a good idea.
- Tucson Tom
Re: Really bad cut.
Well, I certainly have to hand it to you. I never have the foresight to sterilize myself before I seriously injure myself.
As for CA glue, it is your hand and body -- CA glue was, as I understand, developed for field use by injured servicemen during the Vietnam war,
so it is not an unreasonable thing to use.
My worry is infection -- especially if you cut all the way down to the bone. Bone infections are a serious pain in the ___.
Keep a close eye on it and if there is any sign of infection, get to some medical aid.
I am a huge fan of peroxide, and have had great results with it, but on much less serious and less deep infections.
Re: Really bad cut.
Either have a curved needle and thread with someone that knows how to sew or go to a pro. Crazy glue would be my last option.
Re: Really bad cut.
zhyla wrote: ↑Sun Oct 07, 2018 12:44 pmThe problem I’ve had with CA glue is it doesn’t hold long enough. For deep cuts you need something that will maintain pressure for several days, and glue peels off soon because the skin lets go. I’ve made do by re-gluing as I noticed it failing.
I keep a tube in my first aid tin that I keep in my bag with me 24/7, I usually glue it initially but it really depends on how deep it is. I don't need doctor bills and I don't mind scars but I don't need to lose a finger to infection either.
Re: Really bad cut.
I also am a firm believer in steri strips and buy bulk for me and the kiddos. Sure beats super glue when trying to clean the wound and allows for triple antibiotic to find its way into any remaining cut that hasn’t self healed, as compared to super glue. But when in a pinch, duct tape.zhyla wrote: ↑Sun Oct 07, 2018 12:44 pmThe problem I’ve had with CA glue is it doesn’t hold long enough. For deep cuts you need something that will maintain pressure for several days, and glue peels off soon because the skin lets go. I’ve made do by re-gluing as I noticed it failing.
Re: Really bad cut.
My neighbor is a PA and told me bacteria getting trapped in the wound is the only real downside. You definitely want it clean before gluing. It’s not really a big deal, but if it gets infected and you have to pull the glue off that’s a bad day.
Re: Really bad cut.
Take this as you will.
I'm a former Army Medic, EMT-I, and have worked in the medical field for 19 or so years. When I worked at an Urgent Care Clinic if we got a patient with a laceration to the bone we would send them to the ER. Reason being was for better imaging studies to make sure nothing important was cut and no chipping to the bone. A prescription for Antibiotics is given the majority of the time because of the risk of a bone infection.
Just something to think about for the next time.
As for now I'd just recommend you watch for any signs of infection (redness, streaking, discharge, swelling, pain etc). If you start to experience any of that go see a Doc. Also any signs of nerve/tendon damage (numbness, tingling, loss of range of motion, pain with movement, etc) go see a Doc.
Re: Superglue for wounds
It works, but it does contain toxic chemicals and should not be used in deep cuts - only applied across the outer edges of the cut. Dermabond and other medical grade glues are essentially non-toxic super glue. Even then, the stuff is still only applied along the outer edges of a laceration. Also avoid using Gorilla Glue. Gorilla Glue expands as it hardens to fill in cracks - not the best stuff for a cut. How do I know? I have a scar on my middle finger tip from using it :) Wife left a pointy bread knife in the sudsy sink water an did not tell me when I went to wash the stuff.
Re: Really bad cut.
I did just what the OP did across the top of 2 fingers, cut deep, still got two white lines/scars.
Re: Really bad cut.
All the above advice regarding medical treatment and stitches is excellent.
Xacto Knife Blades are used extensively where I used to work, and they are as sharp as a scalpel.
I've successfully used "butterfly" tapes to temporarily stitch a wound to control bleeding, wrap in gauze, and transport to hospital for further medical attention.
- Attachments
- 500158-2T.jpg (49.79 KiB) Viewed 2252 times
North of 49
Re: Really bad cut.
Here’s an update. The first two photos were the day after, LAST photo was taken today! It was easily halfway through, or better. It has sealed up though! No more glue, or anything. And no stitches lol
Im happy it’s almost over.
- curlyhairedboy
Re: Really bad cut.
you're lucky you didn't slice a tendon :O
Re: Really bad cut.
That was my first thought, there's got to be some tendons there otherwise we couldn't straighten out our fingers.
Re: Really bad cut.
Hope you get it taken care of and heal fast!
To anyone thinking 8Cr13MoV is low end, it doesn’t matter, it’s sharp! I just got bitten with light tap of my byrd hawkbill to the back of my index when releasing the lock, just by the weight of the blade when my finger wasn’t forward enough to catch the kick. Blood seeping out immediately, how sharp it is :cool:.
Edit to add: glad you’re healing and no sign of infection. Replied when reading first page :o
@JD Spydo,
You need to check out 8Cr13MoV. This steel works well for both PE & SE :cool:.
@JD Spydo,
Chris :spyder:
