What's k390
Re: What's k390
I would whole heartedly welcome a K390 stretch given it wouldn't have a micro chipping or chipping issue.
Re: What's k390
Petroleum Jelly is better as it is mineral oil that stays on the blade.Midnightrider wrote:Thanks, yeah I'm aware of these issues. I am not sure at this point if it will be used for food after all. If so, I'll try to find some mineral oil insteadDoc Dan wrote:Vaseline is safe to consume if you use it in small amounts on a knife blade. Ballistol is not recommended for consumption, so if you use your knife around food, I suggest Vaseline as it is simply mineral oil with paraffin that helps it stay on the blade.
