Anyone tried to use a Manbug as a hunting knife?
bdblue
Post by bdblue »
The critical element for processing a deer is .... a sharp edge.
Size is secondary.
Over 30 years ago I went hunting with my college roommate. He was a boy scout and carried a small backpack with his gear in it. He shot a deer and then we discovered that his hunting knife was very dull and wouldn't work for us. I was carrying a small Uncle Henry traditional but it was sharp so we used it to process the deer.
Someone mentioned a 3" blade skinning knife, but it likely had a larger handle. A 2" manbug has a blade slightly smaller than the blade of the 3" skinning knife, but probably a lot smaller handle. But still if that is all that you had, a 2" manbug would do the job if it is sharp enough.
Minibear453
Post by Minibear453 »
Blerv wrote:Ambition is all you need :) . They used to skin animals with rocks and volcanic glass.
So what about the ambitious? :P KK bad joke
Carry a sharp knife, and life will never be dull
Manix Guy 2
Post by Manix Guy 2 »
Friend uses a Meercat to field dress deer so Manbug could work , I would sva the heavy work for a bigger model . Regards MG2
Manix Guy 2
Friend uses a Meercat to field dress deer so Manbug could work , I would save the heavy work for a bigger model . Regards MG2
Post by Doc Dan »
[quote="bdblue"]The critical element for processing a deer is .... a sharp edge.
Size is secondary.
Well, with the Manbug, you do not have to worry about it being SHARP!
I have skinned many animals with an Uncle Henry, Tree Brand, Case, and other traditional knives that were sharp. I have also skinned and cleaned fish weighing hundreds of pounds with smaller knives. (30 years ago...we must be the same age, or there about. I can well remember the highest tec knife was a Buck 110 and it was not even called a 110 when I got mine. Still have it.).
RJNC
Post by RJNC »
I'll have to try one of mine when i go bird hunting.
