phillipsted wrote:I'm not sure how much faith to put into commercial Janka ratings. Cocobolo rates around 1100 on lists I've seen, but every piece of cocobolo I've worked with was as hard as any ebony or lignum vitae I've used. I'm sure there are wide variations by species, tree-to-tree, and even within the tree itself (heartwood vs sapwood). So don't put too much faith into these ratings...
Lignum Vitae is really tough, dense oily stuff though. Same with Ironwood and most cocobolo.
TedP
Janka hardness measures hardness only. It is the pounds force required to push a .444" steel ball to half of its diameter into the wood. How the wood resists abrasion and cutting is a different matter.
When my brother had Ray Laconico make a couple fixed blades with desert ironwood handles (from scales that I had) he had problems with the wood being so oily that the sawdust gummed up his belts. I have seen similar behavior with cocobolo; one time I was cutting scales from cocobolo and macassar ebony at the same time, and, while the macassar left fine dry sawdust, the cocobolo sawdust was all clumped together with the oil. And the cocobolo was noticeably easier to cut with a bandsaw.
Same goes for Lignum Vitae, I cut some scales from a block and found the wood quite interesting, very oily. Lignum is in a class by itself, in addition to being very hard (janka hardness 4500) it is very tough. It has been used for bearings - in fact, if you visit the WWII submarine Pampanito that is docked at Fisherman's Wharf in San Francisco, the propeller shaft bearings were made from lignum vitae.
