Sharpmaker flats
rycen
Post by rycen »
TheNeedyCat wrote:flats take more metal off due to the bigger surface area
that is just not correct.
We would rather be the knife in your pocket, because is "works" better, than the knife in your showcase, because it "looks" better.
chuck_roxas45
Post by chuck_roxas45 »
I'd like to disagree. IMHO, the corners concentrate pressure in a very small area and will allow you to take of more metal with the same pressure. That is why I use the corners only when my knife is duller than usual and will take longer than usual on the flats.
