Spyderco Bushcraft Handle Tutorial
- C_Claycomb
I used 1/4 hidden bolts with 3/16th shanks.
I could not figure out what size the lanyard was meant to be, I would have used 1/4 and had slop in the hole, but decided instead to open out the hole. Heating with a torch would have been easier, but I used a carbide drill bit to take it to 8mm, which suits a 5/16 tube pretty well. If you soften the steel you can use a wider range of drill sizes to suit whatever tube material you have handy.
