Manix CTS pics
I posted a reply on YouTube, but I'll say it here - that's a great mod. I am thinking that doing it with a drill press or similar fixed equipment and a ball-shaped burr could make it look just like it came that way from the factory. I think I will put this on my to-do list - probably try it on the $80 regular M2 first. Thank you for posting this.
Sure, why not? Here it is:sal wrote:Very nice pics Vassili, thanx much.
Now we need a picture of Carpenter's CTS-XHP whittling a hair.
http://www.youtube.com/watch?v=S-3lFQjx5i4
What do you think about lock modification?
Thanks, Vassili.
No... Sorry. It was pretty good - hair dance on it. Hair is like palm tree - has some microscopic shells on the surface. Factory edge was able to make hair kind of jumps on those shell bumps, but was not good enough to go under and engage cut.sal wrote:Great video Vassili. Is that the factory edge?
I resharpen blade and polish edge to my taste.
Thanks, Vassili.
I recollect that G-10 in particle form is nasty stuff. I think STR has some horror stories about it. If you perform the modification, play it safe and wear a respirator (not just a dust mask).
Point is to unlock it with one finger, which is a case for all knives with locks on a market and so common user experience-expectations.Seanski wrote:unlock it with two fingers then swing snap it shut? Is this hard on a knife like
this or does it cause any stress to it? Thanks.
Also there is nothing wrong with this lock itself (which I like more then many others) - this is unusual for Spyderco luck of attention to details, I would say. Just too thick scales, no access to lock head, which make it hard to use expected way. And this is pretty easy to fix with my Dremel and I hope in factory environment as well.
I do not agree with Sal, this modification did not make it too easy or even easy to unlock - it just make it possible to unlock normal way (with one finger), it is still impossible to unlock by accident.
Thanks, Vassili.
