Best knife for hard use?
bladese97
Post by bladese97 »
:spyder: :spyder: :cool: :spyder: :spyder: I wonder what type of lock are you looking for, and blade steel; However, my sugjestios are the Atr, the Chinook, the Manix/full&mini, and D'allara. All excellent choices for hard use, and give you a variaty of lock types. I hope the mini Manix will satisfy your cutting purposes; I own one, and carry it often! Don't let the term 'mini' intimadate you...It is just as :eek: :eek: SHARP, and brutil as the full size!
:spyder: :spyder: :cool: :spyder: :spyder: "Spyderco...does a pocket good":spyder:
Spyderco Rocks!!!! "A wise man once said all knives were created equal...Obviously, he meant Spydercos''
As of 1-29-08, I am a proud member of Knife Rights!
Billy
Paramilitary
Post by Billy »
Unless I'm mistaken, no one has mentioned the Paramilitary. Blade length of under 4", open back, comp lock, S30V steel with spine and choil jimping, ergonomic G-10 scales...what more could you ask for? The very first day I got my PE Para, I gave it a nice hard workout doing lawn chores and repairing sprinkler stuff - lots of grit, grime, sandy dirt and cutting of plastic pipes and some foliage. I actually thought I busted the tip a couple of times while I had the blade inserted between some torn sprinkler pipe and pvc pipe. I was twisting the blade pretty hard in an attempt to cut the torn, threaded piece so I could remove it and heard it pop, but it wasn't the blade, thank goodness. Para's are seriously under-appreciated, if you ask me.
Billy
I LOVE MY MILLIES
ΜΟΛΩΝ ΛΑΒΕ
