Cleaning Tri-Angle Sharpmaker ceramic stone
Devils_Advocate
Post by Devils_Advocate »
I've been using the white eraser--the ones for pencil--on my sharpener with great results. By the way, the 204 is great and the ultra-fine stones get's blades sharper than sharp (if that's possible). WOW!
People who think they know it all are especially annoying to those of us who do.
Joe Talmadge
Post by Joe Talmadge »
Andyy wrote: And i tried scrubing with comet and scour pads (scotch Brite, 3M). This worked the best for me.
There ya go. Now switch to a steel wool scouring pad instead of a plastic one, and you'll have arrived at the right answer :)
Andyy
Post by Andyy »
I realize that what should happen is that the metal scouring pad gets "sharpened" by the stone, and clogs it up even worse. However, due an extremely complicated quantum tunneling effect, that you'd need to understand M-theory to even remotely fathom, this doesn't happen. Instead, the stones come out squeaky clean in seconds, no muss, no fuss, no special chemicals or erasers, no pre-soaking.
by the quantum tunneling effect, you are refering to the tow states a metal scouring pad can exist inn at the same time?
Both inn the pores on the "stone" and on the outside.
Devils_Advocate
knives and quantum mechanics
Andyy wrote:However, due an extremely complicated quantum tunneling effect, that you'd need to understand M-theory to even remotely fathom, this doesn't happen...
...by the quantum tunneling effect, you are refering to the tow states a metal scouring pad can exist inn at the same time?
Couldn't have said it better myself. By the way, I bet know one here knows what the M stands for.
Keep 'em sharp,
D.A.
Joe Talmadge
"M stands for Magic, Mystery or Membrane, according to taste."
I figure if Witten isn't sure, no one is :) I remembered seeing a quote when reading about M-theory (that's reading about it, not trying to do the math!), and google came to the rescue.
999
Post by 999 »
Just tried a steel wool scouring pad (Brillo pad). They did come up nice but I think I'll still use the eraser for most of the time, but giving them a 'deep' clean every month or so.
Dave.
