I'm sure St Nick's will have a Red G10 DLC 4V PM2 out before the end of the year. Their 4V Para 3 has reached legendary status.
DLC 20CV PM2?
- steelcity16
Re: DLC 20CV PM2?
- rabbitanarchy14
Re: DLC 20CV PM2?
absolutely perfect. awesome. satin is the best, no wear on the black making it look all scratched up.Paul-DLT wrote: ↑Wed Jun 05, 2019 11:03 pmsteelcity16 is correct. They will be satin blade.rabbitanarchy14 wrote: ↑Wed Jun 05, 2019 10:46 pmso just a question? will these be satin blades or dlc. if it is satin and red g10 with m390. i will be saving my money now.
192.168.0.1 -Para 3 G10 M390 Red, Dice XHP, Lil Native Rex 45 comp, Manix 2 M390 G10 BR, PM2 M390 DLC BL, PM2 k390 RGreen, Cat BD1N, Dragonfly 2 k390
Saving for - Lil Native K390, D'allara 3, UTX-70
Instruments- Kimber EVO, SA Hellcat, SW Shield Plus 9
Re: DLC 20CV PM2?
In defense of black, if it's DLC...it takes A LOT to actually scratch up the blade. Chances are you're seeing material from what has been cut on the blade, not actual scratches on the blade itself. DLC cleans up very well with some Flitz and then a little mineral oil to bring back the shine.
Before...
After...
Before...
After...
15 's in 10 different steels
Re: DLC 20CV PM2?
This tid bit of info should be included in the box with every DLC bladeTkoK83Spy wrote: ↑Fri Jun 07, 2019 6:32 amIn defense of black, if it's DLC...it takes A LOT to actually scratch up the blade. Chances are you're seeing material from what has been cut on the blade, not actual scratches on the blade itself. DLC cleans up very well with some Flitz and then a little mineral oil to bring back the shine.
Before...
After...
- steelcity16
Re: DLC 20CV PM2?
+1 DLC is great. As said, the DLC is VERY hard (hence DIAMOND Like Coating) and it isn't going to scratch unless heavily abused. And even it you use it hard enough to puts some actual wear on it, naturally worn DLC looks 1,000 times better than a random patina or scratched SUS410 cladding in my opinion. DLC is my favorite blade finish by far. I would love to see more knives use it. Thank you to all of the dealers who use it on their exclusives! :D
Re: DLC 20CV PM2?
I wish now I’d snagged the dlc BHQ para3. Oh well.
Re: DLC 20CV PM2?
A few other before and after pics of DLC I took a while back...nobody should ever be scared away from a DLC blade!
Re: DLC 20CV PM2?
Thanks for the tip! That's really impressive how well it cleans up. That is definitely a good tidbit of info that Spyderco should consider including in the box.
- HarleyXJGuy
Re: DLC 20CV PM2?
Had my 110V Manix made stupid sharp by a guy here in Michigan and it has finally broke in so that the blade drops freely when I close it. Loving it a good bit more then I did.
Seeing how the DLC cleans up makes me regret not getting one of the Grey/DLC Manix
- HarleyXJGuy
Re: DLC 20CV PM2?
Just rub on some Flitz with a cloth?TkoK83Spy wrote: ↑Fri Jun 07, 2019 6:32 amIn defense of black, if it's DLC...it takes A LOT to actually scratch up the blade. Chances are you're seeing material from what has been cut on the blade, not actual scratches on the blade itself. DLC cleans up very well with some Flitz and then a little mineral oil to bring back the shine.
Before...
After...
Re: DLC 20CV PM2?
Yep. I use an old tee shirt. Very easy!HarleyXJGuy wrote: ↑Sat Jun 08, 2019 8:14 pmJust rub on some Flitz with a cloth?TkoK83Spy wrote: ↑Fri Jun 07, 2019 6:32 amIn defense of black, if it's DLC...it takes A LOT to actually scratch up the blade. Chances are you're seeing material from what has been cut on the blade, not actual scratches on the blade itself. DLC cleans up very well with some Flitz and then a little mineral oil to bring back the shine.
Before...
After...
- HarleyXJGuy
Re: DLC 20CV PM2?
Excellent, thanksTkoK83Spy wrote: ↑Sat Jun 08, 2019 9:34 pmYep. I use an old tee shirt. Very easy!HarleyXJGuy wrote: ↑Sat Jun 08, 2019 8:14 pmJust rub on some Flitz with a cloth?TkoK83Spy wrote: ↑Fri Jun 07, 2019 6:32 amIn defense of black, if it's DLC...it takes A LOT to actually scratch up the blade. Chances are you're seeing material from what has been cut on the blade, not actual scratches on the blade itself. DLC cleans up very well with some Flitz and then a little mineral oil to bring back the shine.
Before...
After...
Re: DLC 20CV PM2?
The DLT Exclusive ParaMilitary2 CPM-20CV Black DLC Blade Tan G-10 DLT Trading is coming back in stock for $175 on Tuesday, June 7, 2022 at 11:00am CT. These were first released in May 2019 for $149.
https://www.dlttrading.com/spyderco-par ... lade-52022
$175.00 is still a very good price for a PM2 with 20CV, DLC and G-10 considering the regular production PM2 with S45VN, DLC and G-10 is $185.50!
- I welcome dialog, as long as it remains cordial, constructive and is conducted in a civilized manner. - Titanic: Blood & Steel
- You can fool some of the people all of the time, and all of the people some of the time, but you cannot fool all of the people all of the time. - Abraham Lincoln
