Could only handle a Shaman, but owned a Kapara and I think you are onto something.JSumm wrote: ↑Thu Nov 23, 2023 6:28 amI do believe a big reason people switch out those beautiful contoured scales is not just the fault of the smoothness. It is the contouring similar to the Kapara in combination with the compression lock. When you pinch grip to close, if you look at your fingers they can end up north or south of the contouring and the pinch can sometimes push the knife out of your grip. I just don't think contouring works best with the compression lock. If the Shaman and Kapara were backlocks, I don't think you would see as many complaints about dropping them.
I don´t think a Shaman or Kapara would be technically possible in the exact current overall shape with a backlock (the blades would probably not fit into the handles "tallness-wise" with a lockbar).
But a linerlock lock would solve the (potential) "issue" too (and the overall knife shapes could remain the same):
With the way people normally operate linerlocks the knife sits more secure in hand as with the pinch grip comp.lock method, and the fingers are still completely protected due to the choil (at least with the Shaman). Activating the linerlock inevitably means also putting the thumb (or indexfinger) in a place where it has to get hit by the choil and not the edge first and by that protects all the other fingers too..
So with a linerlock Shaman you´d end up with knife sitting more secure in hand plus the "finger safety" some seem to desire (plus better ergos for me personally).
But then I know I am outlier in preferring linerlocks over comp.locks and in wishing for a linerlock Shaman or Caribbean...
