Spyderco Para Military 2 with Carbon Fiber and S90V
SteelDragon
SteelDragon
SteelDragon
SteelDragon
- WireEdge Roger
I really like my CF/S90V Para! It's just a little lighter than the G-10 version. My S90V version has a little more clearance for the Compression Lock, I can push it away from the blade slightly moreso than my S30V version. I think this was done to make unlocking it a little easier. A lot of people complained the Para 2 was hard to unlock when they were first out.
SteelDragon
With at least 3 different Para 2 variations before the CF, which may have been just logo changes so I can't say if I have the latest G-10 Para 2 or not. But the lock design is different between the G10 and CF on the 2 models I have. I will take a closer look later but was just curious if anyone had already looked in to this or was aware of the changes that were being made and why?JNewell wrote:Sprints are almost always just variations in materials, not design/dimensions/etc.
I was finally able to retrieve my PM2 CF/S90V from the post office today. I have the G-10/S30V version too, so I got to do an immediate comparison between the two.
The CF/S90V might be lighter (should be), but it's not immediately noticeable when holding one in each hand. We are talking grams here anyway. Fit and finish are very good on my example with the only issue being some rough spots on the inside edge of the bottom of the scales. I attribute this more to the nature of carbon fiber and not having detailed hand finishing. Not a serious issue on this production folder. I will likely try to sand down the very edge of the inside of the scales, softening the edge for improved feel.
My CF/S90V compression lock is perfect in use. It locks up tight, and opens without any hesitation. Compared to to my G-10/S30V, there are a couple of differences.
It's a great knife overall. For me, it is the perfect EDC design to date from Spyderco.
- The ball bearing detent does interfere as much to the blade swinging closed. There's no hesitation from the blade riding over the ball bearing.
- The spring/bend is further back on the lock bar. This makes the compression lock tip (that meets the blade tang) lie flatter into the cut out channel in the handle when closing the knife.
- The spring tension of the lock bar feels stronger. Maybe this is a result of the spring/bend being longer?
"All your :spyder: are belong to us."
** WTC # 1032 1533 **
