Security concern
damiand
Security concern
Post by damiand »
Hello.
I am grateful that I purchased Chaparral. It was time to have an EDC knife. I removed the clip and carry it loose since I prefer an unconcealed knife.
I do however have a security concern: the tip and the space between the scales . I'm a little worried that the tip is going to puncture my pocket, since the steel ends right before the tip (I'm considering the closed knife). Is there any chance it's going to puncture my pocket? I have tried to simulate that a part of my pocket manages to get into that space using paper and the tip can pierce the paper with little force . Is there any way for this to happen in mu pocket and any way to prevent it? Any model that does not have this security issue? I'm pretty worried, a few millimeters of missing steel could put me at a security risk.
Airlsee
Re: Security concern
Post by Airlsee »
I think you'll be alright. Keep us posted.
So it goes.
VooDooChild
Post by VooDooChild »
Certain designs can be better or worse with this concern.
You can always drop the spine/ lower the tip. This moves the tip down into the handle more.
Rymanz
Post by Rymanz »
Don't wear any pants. No pockets = problem solved! Only downside is you'll have to get more inventive with your concealment technique.
:bug-red
damiand
Post by damiand »
VooDooChild wrote:
Thu Jan 20, 2022 4:14 pm
How can I do this in Chaparral?
The Mastiff
Post by The Mastiff »
Please post a picture of what you are talking about. Your description is confusing.
damiand
Post by damiand »
The Mastiff wrote:
Thu Jan 20, 2022 4:28 pm
The tip is not protected by the steel on the side.
Airlsee
Post by Airlsee »
At least you got the important part in focus...
So it goes.
VooDooChild
File down the spine near the tip. Or use a sander/grinder if you want to take off a lot of material but you have to be very careful.
You are, in a sense, reshaping the blade, but all you are really doing is moving the tip down. Which will also move the tip further away from the opening in the end of the handle.
Airlsee
Post by Airlsee »
No one wants to tell him to file down the kick?
I still think scissors are the best option for our friend.
ETA: His Chaparral is fine.
So it goes.
sethwm
Post by sethwm »
VooDooChild wrote:
Thu Jan 20, 2022 4:36 pm
Don't do this. Yes, this advice is helpful, but I mean you, personally, should not do this. I think you're in over your head.
damiand
Post by damiand »
sethwm wrote:
Thu Jan 20, 2022 5:41 pm
Why shouldn't I do this?
damiand wrote:
Thu Jan 20, 2022 6:07 pm
because, if you can't open a pocket knife without cutting yourself, you definitely shouldn't be operating a power tool (or even a hand tool), especially in the vicinity of your knife blade.
damiand
Post by damiand »
Thu Jan 20, 2022 6:15 pm
Yeah, I don't know how to do it. Whenever I try to open my Chaparral it closes on me and my finger gets caught. It seems that I have to use more force but I don't want to break my knife.
steelcity16
Post by steelcity16 »
^ This can't be real.
prndltech
Post by prndltech »
Just don’t reply. It’s that simple.
MNOSD 0006
I don't see what the issue is here. Unless the OP's knife is somehow drastically different than mine there's nothing to be concerned about
jacala
Post by jacala »
Grind all the sharp corners and edges off , just to be sure.
A metal pocket liner would also be a good idea.
sethwm
Post by sethwm »
jacala wrote:
Thu Jan 20, 2022 8:04 pm
What about chainmail pants?
kobold
Post by kobold »
When they asked people on their death beds about their biggest regrets, the most common answer was "I worried too much".
