A linerless Ti Manix 2 (lots of pics)
ferider
Post by ferider »
Starting from the newly available Flytanium Manix 2 scales, a donor Manix backspacer and a spare Manix LW Pivot and Pivot screws that I had.
To replace the scale screws, you need 4-40 3/16 100 degree torx screws (a bit shorter than stock). Then you need to drill open the Flytanium Pivot holes. Finally make the lanyard spacer a bit shorter and voila.
Compared to a lined Manix (sceletonized) with Rockscale Ti scales (lighter than Flytanium since they have machined gaps for weight reduction)
Will replace the pivot screws in the pics with undercut 4-40 flatheads soon.
The knife feels great, amazingly thin, slicy and light. I don't use pocket clips on most of my knives, in case you wonder. Probably can ask the Flytanium guys to skip the holes or make them smaller, so they can be tapped matching Spydie clip screws.
Cheers,
Roland.
Re: A linerless Ti Manix 2 (lots of pics)
I really want to do this with G10 but I want the scales made twice as thick so I can contour them.
Zatx
Post by Zatx »
That is awesome; love projects like this! This looks like a bigger Chaparral, but with a better lock (can't stand back locks)!
Have you thought about sanding down the tabs for the lock so they sit lower?
TomAiello
Post by TomAiello »
That's amazing. Definitely awesome.
attila
Post by attila »
That is really awesome!
Want: SPY27, K490, Swick 5
Well done! I really like the linerless ti folders, thin but solid.
spyderg
Post by spyderg »
Great job on a great mod!
Post by Doc Dan »
Very nice, indeed. I wonder what such a knife would cost if Spyderco made this in Golden? Probably a lot more than I can afford.
That's great!
zhyla
Post by zhyla »
Evil D wrote:
Fri Feb 15, 2019 12:32 pm
Yeah, want to do the same. I have some OD micarta 1/4” slabs set aside for this. I have a CNC so if I had a 3d model or spend some time making a model I can do that.
I wonder if there’s a 3d scanner service out there that is really accurate. I really want this to be dead-nuts perfect.
ferider
Post by ferider »
Thanks all.
I've been debating this, not hard to do. But I actually like the tabs sticking out so far, makes the knife easier to close, even with one finger. Form vs. function, I guess I'll be picking function ....
Roland.
zhyla wrote:
Sat Feb 16, 2019 9:10 am
I can shape it myself, I just need someone to make all the proper holes in the right places and counter sink the holes and such. I could even work with rectangular slabs and do the whole shape myself (I'd actually kinda prefer that).
ferider
Post by ferider »
Update:
- hard to find better Pivot Screws, so I decided to "countersink" the washers instead and am happy with the results.
- Carried the linerless M4 Manix for a couple of days, and really like it. So I decided to do a second one, stainless and hollow ground, as a complement for rainy days: :)
Roland.
rabbitanarchy14
Post by rabbitanarchy14 »
Wow those are amazing. Really good job. i know i should not ask but what if you made a Ti or ss ball carrier.
192.168.0.1 -Para 3 G10 M390 Red, Dice XHP, Lil Native Rex 45 comp, Manix 2 M390 G10 BR, PM2 M390 DLC BL, PM2 k390 RGreen, Cat BD1N, Dragonfly 2 k390
Saving for - Lil Native K390, D'allara 3, UTX-70
Instruments- Kimber EVO, SA Hellcat, SW Shield Plus 9
gull wing
Post by gull wing »
Great mod.
SCARAMOUCHE! :bug-red-white
Username827
Post by Username827 »
That is awesome
