Maybe Deadboxhero will join in with one of his rex121 customs and a steel 50 gallon drum :D
- JonLeBlanc
I was not aware the WolfSpyder had a Scandi edge, or did you put it on yourself?DirtMcGirt wrote: ↑Tue Jun 11, 2019 5:00 pmSteelcity, I guess so. I went ahead and did it again. Only this time, I used the Wolfspyder. It’s in my pocket most of the time, so I wanted to see how it would fare. No edge damage from the bucket(see 2nd pic though). But no where near the same experience as using the PM2. The Wolfspyder didn’t want to go straight through. Wanted to trail either right or left. Also had a tougher time at the corners. I believe the scandi grind played a role in all that. Where as the PM2 went straight down and zipped through the corners. I am definitely wanting to do it more with different models too.steelcity16 wrote: ↑Tue Jun 11, 2019 12:33 pm
I guess we were the only ones willing to take on the challenge?? :confused: I was looking forward to seeing many more pictures of bisected paint buckets!! Maybe an apple slicing challenge or Amazon package opening challenge would appeal to more folks?? Lol! :D
Honestly though, the whole time I was doing it I felt like a hospital visit was immanent, so perhaps its for the better that no one else attempted this! :)
Hey Bloke. I hastily took your earlier joke as a challenge, and went for the handle too. One solid strike with a 2x4 baton. Lesson learned. This is gonna take a while to repair.....Bloke wrote: Hey McGrit, cutting through the four crimped layers of 0.010” aluminium at the rim of the can was much harder than I anticipated. I slipped once and thought I may have snapped a bit off the tip but much maligned S30V is pretty tough and the only damage was a micro chip a couple of inches from the tip and only because of lateral pressure. As you can see (newsprint and match) for all practical intents the knife’s still sharp. :)
- steelcity16
PeaceInOurTime wrote: ↑Wed Jun 12, 2019 3:53 pmNot so fast! .....HAP40 has arrived.....steelcity16 wrote: ↑Tue Jun 11, 2019 12:33 pm
g
Honestly though, the whole time I was doing it I felt like a hospital visit was imminent, so perhaps its for the better that no one else attempted this! :)
Next time?
Yes! Another contender enters the ring!! Love seeing these pics!!
And please please PLEASE bisect a 55 gallon drum with an Endura!! :D
Happy to see you sorted it out mate. :)DirtMcGirt wrote: ↑Wed Jun 12, 2019 9:20 amNot at all! You never know if you don’t at least try. Sorted it out last night while my wife watched The Bachelorette. Now it’s a scandi-vex.
I take all my Scandis to zero and maintain with a strop so they end up a little convex too in between sharpening.
What did you do to fix it?
It comes scandi. With a secondary microbevel.JonLeBlanc wrote: ↑Wed Jun 12, 2019 5:24 pm
First I ground the entire edge flat using a coarse Norton SiC (more at the belly to remove the chip). Then I cut a fresh secondary bevel with the same stone. After that the knife was sharp again, but I wasn’t happy with the secondary bevel on this knife. So I got out the mousepad and sandpaper. A few passes on 80 to cut the shoulders off, then a few on 220, then to 1000 and a black/green strop. Admittedly I should have used more grits and done a better job removing the scratches. But I am really happy with the results.Bloke wrote:
- PeaceInOurTime
steelcity16 wrote: ↑Wed Jun 12, 2019 5:47 pmPeaceInOurTime wrote: ↑Wed Jun 12, 2019 3:53 pmNot so fast! .....HAP40 has arrived.....steelcity16 wrote: ↑Tue Jun 11, 2019 12:33 pm
g
Next time?
Haha we'll see. I'd hate to ruin a perfectly good drum. On the other hand, it keeps shooting dirty looks at me... And I'm curious how the Endura would handle it...
Ah, hahaha! :)
Ain’t that the truth. :D
Made it 99% through before the tip finally gave. 30 mins of hard stabbing, prying, and twisting. This is one tough bugger.
Wow that's impressive coming from thinly ground CPM S30V!DirtMcGirt wrote: ↑Fri Jun 14, 2019 11:01 amMade it 99% through before the tip finally gave. 30 mins of hard stabbing, prying, and twisting. This is one tough bugger.
How's the edge sharpness?
- Connor
It still scrape shaves at the tip, and pops ‘em off at the heel. It’s not that thin anymore though. I just convexed it the other night, so it’s a bit thicker BTE now.The Meat man wrote: ↑Fri Jun 14, 2019 11:11 amWow that's impressive coming from thinly ground CPM S30V!DirtMcGirt wrote: ↑Fri Jun 14, 2019 11:01 amMade it 99% through before the tip finally gave. 30 mins of hard stabbing, prying, and twisting. This is one tough bugger.
- lonerider1013
You can fix that tip right?
"A fool's blade may be sharper than his brain"
“Learn to ride a bicycle. You will not regret it if you live." - Mark Twain
Just used the Shaman to open up a box with a new bear can for the ol' lady.
Nice pics!
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
These things are pretty cool!
Looks like a monitor-well manhole cover. What’s a bear can?
- lonerider1013
slicing an icky callous off my right hand (sorry I know that's gross).
lonerider
lonerider
A bear can is a bear "proof" cannister for storing your food and smellies in when sleeping in the backcountry in bear country. It's a specialized tool for backpacking. This one is as light as possible, made of carbon fiber and aluminum.
Thanks for the explanation.
