Page 1 of 1
how can i clean g 10?
Posted: Wed Jan 12, 2011 4:28 pm
by dzarren
I recently acquired a new manix 2 in orange g 10 and around the cage ball lock on the g 10 theres already a bunch of crap accumulating from my hands rubbing agianst it while i disengage the lock, even tho i am usually washing my hands before i touch this blade, since it is my precious.
is there a simple way to get this stuff off the g 10 without dissembling the blade? and when it gets dirty enough to the point where i want to take it apart, what can i use as a solvent to clean the dirty g 10?
thanks.
also i feel this blade would be better suited as a tip down, but i can see why its not.
Try Ballistol
Posted: Wed Jan 12, 2011 4:35 pm
by pleeho
if that doesn't work, maybe some turpentine?
Posted: Wed Jan 12, 2011 4:40 pm
by Handwrecker
Try some dish soap. And a sponge or toothbrush. Cleaned my orange Millie up perfectly. And definitely no need to take anything apart, except maybe the clip.
by Spider bite
I clean my g-10 with soap and water.
Posted: Wed Jan 12, 2011 4:41 pm
by Frapiscide
Just a wet toothbrush or perhaps a schotchbrite pad (blue, of course).
Posted: Wed Jan 12, 2011 4:49 pm
by dsmegst
liquid soap and hot water is what I use. An old toothbrush helps for the crevices.
Posted: Wed Jan 12, 2011 4:53 pm
by Bluntrauma
dsmegst wrote:liquid soap and hot water is what I use. An old toothbrush helps for the crevices.
Same here. Too lazy to type so I quoted.
by hiredgun
What others have said, liquid soap, warm water, toothbrush and sometimes I use toothpaste. Gives a minty fresh smell to your knife. :D
Posted: Wed Jan 12, 2011 5:08 pm
by SpydieZ
I thought I heard if you use warm water instead of cold it will fade the g-10? Maybe I was told incorrectly
Posted: Wed Jan 12, 2011 5:55 pm
by The Deacon
+1 on the dish detergent, warm water, and a toothbrush.
SpydieZ wrote:I thought I heard if you use warm water instead of cold it will fade the g-10? Maybe I was told incorrectly
Urban legend.
Posted: Wed Jan 12, 2011 7:43 pm
by SQSAR
After a good cleaning with a mild detergent and a toothbrush, i will sometimes put a hint of miltech on the edges of the G-10 and rub/work it in real well. Kind of gives new life to G-10 when its starts to show its age.
Posted: Wed Jan 12, 2011 7:59 pm
by spyderfan123
dzarren wrote:I recently acquired a new manix 2 in orange g 10 and around the cage ball lock on the g 10 theres already a bunch of crap accumulating from my hands rubbing agianst it while i disengage the lock, even tho i am usually washing my hands before i touch this blade, since it is my precious.
thanks.
compressed air pistol+a wet sponge always work!
Posted: Wed Jan 12, 2011 8:57 pm
by msierant
greetings all,
a soft toothbrush with water only. lightly q-tip some wd-40 and your g10 will look as good as new. works for me all the time. the wd-40 brings it back to life.
