Pick One Favorite.
Re: Pick One Favorite.
SMKW green fat carbon blade swap to s110v. I finally found a set of scales I like on pm2’s.
- Haunted House
Currently… the DLT Cruwear Endela.
BigFishShamu
Thank you!Erion929 wrote: ↑Tue Jun 20, 2023 11:32 pmBigFishShamu wrote: ↑Tue Jun 20, 2023 5:04 amHow difficult was the AWT scale swap? Been looking into getting some for my Manix but I’ve only ever scale swapped like one on my Demko… That build looks great![]()
The scale swap was simple! Because you are also deleting the lanyard tube, you don’t even need to separate the G10 scales from the lanyard tube….just remove it all in one piece. So, you just take body/pivot screws out of the knife, swing one scale/liner out of the way, jiggle out the cage/ball/retainer piece, and basically put it back together with the AWT scales.
(Just determine beforehand if you are going to replace the cage, ball, or spring with aftermarket parts)
Take a moment and observe the alignment of the cage/spring/ball as you swing out the scale/liner. There are lots of YouTube vids on disassembly, even ones changing to AWT scales. After the first time, it gets easier and easier….I took mine apart 3 times as I was trying in different springs. It’s not as hard as some make it seem, if you watch good vids.
BigFishShamu wrote: ↑Fri Jun 23, 2023 1:36 pmThank you!Erion929 wrote: ↑Tue Jun 20, 2023 11:32 pmBigFishShamu wrote: ↑Tue Jun 20, 2023 5:04 amHow difficult was the AWT scale swap? Been looking into getting some for my Manix but I’ve only ever scale swapped like one on my Demko… That build looks great![]()
This is one of the more easily understood Manix disassembly vids
https://youtu.be/H0uDgVEZB2A
This one is more AWT-specific
https://youtu.be/4KDTxAb-Xr4
Between the two, should be good-to-go
Today it’s the new super blue/sus410 zome delica with a TiCN coating
-Ryan
MNOSD member #00053
MNOSD member #00053
New #1 until it‘s offered in a salt version
And why whatever I might have said last week, or the week before that, is likely to change this Wednesday when my first Leaf Jumper (K390) is due to arrive.
Polling for a favorite Spydie misses the whole point of exploring different Spydie models.
Ha!!! So true…a magnacut version would trump this and the Dfly Salt never leaves my pocket until whatever I’m wearing gets thrown in the hamper…lil native salt…microjimbo…a backlock Caribbean or one with Golden detent…the list goes on
I can refine my 'Native 5' response to my new Franken-Native 5. Magnacut blade and backlock, Stormtrooper white scales, silver clip from a burnt orange Native 5. Very 'clean' looking knife for fishing. Can't wait to get fish guts on that white handle. Strange plan was to dye the scales to look like a trout, but not sure that's feasable.
For me first it was the Sage 5, then the CruCarta PM2, then the Slysz Bowie, and now it’s the GB2. Ask me in a year and it will have been 3 others…
I’m just a sucker for the M4, hollow grind, and liner lock. It’s an actual Sebenza killer - but don’t tell my Sebenzas I said that.
- dj moonbat
This was my favorite, until it fell out of an unzipped backpack pocket, never to be found again.
Of the knives still in my possession, the Rockjumper SE is my favorite.
Mine is the Military.
If I had to pick just one, it would be my blacked-out Yojimbo 2. It's my most-used & carried work folder at this point, so I'd go with something familiar.
wirelessjunkie
For me, it's the Hap40 Endura. The Endura platform has been my favorite for a long time, but this one model always finds a way back in my pocket over the others I have. The handle color is nice, and Hap40 is just a good well rounded tool steel to use and sharpen.
Rock Jumper SE is my next onedj moonbat wrote: ↑Fri Jun 30, 2023 9:48 amThis was my favorite, until it fell out of an unzipped backpack pocket, never to be found again.
Can't decide between the Native CF S90V and the PITS. But this is only for the warm season.
For the cold season I can't decide between the Military and the CF S90V Native Chief.
crazywednesday
