Military is back in stock!
Re: Military is back in stock!
DLC itself does not help with corrosion resistance
It does not prevent corrosion but it definitely helps to resist it.
How can that be if it’s porous?
Yeah you and me both. I'm EDCing my M390 Millie today. It's been my favorite of all the Military models I've ever owned so far. I just love that M390 blade steel. It's been the best C-36 Military model I''ve ever owned and I have used it on a lot of demanding jobs. The XHP version is awesome as well.phaust wrote: ↑Fri Jan 07, 2022 1:19 pmThe carbon fiber makes a big difference. The all cf version is down at 4oz.Wartstein wrote: ↑Fri Jan 07, 2022 1:09 pmHopweaver wrote: ↑Fri Jan 07, 2022 8:06 amBest knife in the Spyderco catalog IMO!
My favorite version of the Military is the Knifeworks exclusive. It was Carbon Fiber and Titanium with a Reeve Integral Lock (R.I.L.) mechanism and S90V blade. I love the R.I.L. on the Military.
https://www.spyderco.com/catalog/detail ... usive/1189
Amazing how this one is really not much heavier than the linerlock versions (4.8 vs 4.5)
I regret selling my m390/cf model for that reason. Wasn't a fan of the RIL Ti/CF version and don't regret letting that one go though.
I would love to see the C-36 Military done in more selections of Bohler-Uddeholm blade steels. The C-36 Military and Para2 models are thee best for introducting newer/better blade steels IMO.
This is very interesting and I appreciate information.
Could you also speak to DLC as a relates to helping rust resistance?
NONE/ZERO/ZIP of the Family of Vacuum Deposited Coatings ARE GOOD Corrosion Barriers, That being said, these coatings can’t rust because these is no presents of Iron/Ferrite in the coating itself.. It’s a coating only 2-4 Microns in thickness with microscopic pin holes, corrosion can start there and on the cutting edge migrating under the coating causing rust…
The Benefit of coatings for corrosion is they absorb oil like a sponge, Maintain your knife, rinse it off from time to time and reapply a coat of oil, wipe dry and you’ll have Great Corrosion Protection…
We all want a knife that, Won't Rust, Light Weight, Stays Sharp forever, with the latest materials.. It doesn't exist, But were working on it... almost forgot.. For Under $100.00 Made in the USA...
Darrell
Quote above is pulled from
https://www.bladeforums.com/threads/dlc ... n.1122962/
Darrell
whoever wrote that had a much different experience than I did.
viewtopic.php?t=89798
there's another dlc corrosion experiment. note the uncoated areas showed more rust vs the coated.
that author has also never heard of my favorite pocket knife, the pacific salt :) It'll stay sharp for a couple of months and was made in japan, otherwise meets that criteria
siren comes close too outside the price!
- kennethsime
I really can’t wait for a K390 Military. I might stop buying knives after that.
- senorsquare
I think all that rust is bleeding from the pivot area.
- I welcome dialog, as long as it remains cordial, constructive and is conducted in a civilized manner. - Titanic: Blood & Steel
- You can fool some of the people all of the time, and all of the people some of the time, but you cannot fool all of the people all of the time. - Abraham Lincoln
you need to learn to maintain your knives bro
In all seriousness, my m4 manix xl experiments proved to me 2 things, based on my history with M4 steel. dlc doesn't make m4 rust proof - but it makes it a **** of a lot more corrosion resistant than bare m4.
using my m4 chiefs side by side - one dlc, one satin - same thing.
i see comments about dlc knives forming rust under the dlc. try the smell test. smell a corroded carbon blade then a clean stainless blade. sounds stupid I know, but corroded carbon blades have a distinct smell to them.
vivi wrote: ↑Tue Jan 11, 2022 11:47 amyou need to learn to maintain your knives bro
And taste!
- kennethsime
In case anyone is still looking, DLT has the Digi Camo Millie in stock.
well we know who the window licker of the crowd iskobold wrote: ↑Tue Jan 11, 2022 6:34 pmvivi wrote: ↑Tue Jan 11, 2022 11:47 amyou need to learn to maintain your knives bro
And taste!
MNOSD 0006
