The Sliverax
The Sliverax
Now that I have my Military 2 speeding its way to me thanks to DLT, I've got the "spyderco disease" and now I'm looking at picking up the Sliverax on Friday. The more I look at this knife, the more I like it. Does anyone here have any reason why I shouldn't? Anything I should know about?
Thanks in adv.
Thanks in adv.
Re: The Sliverax
It's a really cool design but since it has been discontinued for a few years it may be tough to track down.
I'd be interested in a fixed blade version. I came up with a fixed blade design that was very close to a fixed Sliverax.
Re: The Sliverax
The reason I saw it is because I was browsing on DLT and it showed as in stock. Okay maybe I shouldn't wait until Friday
Re: The Sliverax
Yeah I'd jump on that right away if you're interested. Unlikely another one will ever roll off the production line, and saves you from having to hunt one down on the secondary market.
Re: The Sliverax
I have three of them
It's ranked very very high on my favorites list. It's a quirky design though, and people seem to love it or hate it. It's my go-to model for more formal dress. The biggest flaws I think people see are 1) the flipper tab will hit your finger if you don't move it off the lock tab when dropping the blade closed and 2) the detents are on the weaker side which can make flipping weaker and sometimes unreliable. You can tweak the detent to make it stronger if you're comfortable doing that sort of thing, one of mine has been modded and the flipping action is significantly better than the other two. You can also grind off the flipper tab entirely if it's not your thing, I've done this to one of mine and it functions just fine as a thumb opening only knife.
Here's my bobbed version.
Re: The Sliverax
I had big detent issues. It was too weak. I could shake it open quite easily.
Design is great. I also liked the negative angle of the blade.
Re: The Sliverax
Thx for the lengthy review! I just order one while still in stock. That picture is awesome it is a very nice looking nknifeEvil D wrote: ↑Wed Jul 26, 2023 2:43 amI have three of them
Re: The Sliverax
ImHereForTheMilitary2 wrote: ↑Wed Jul 26, 2023 7:17 amThx for the lengthy review! I just order one while still in stock. That picture is awesome it is a very nice looking nknifeEvil D wrote: ↑Wed Jul 26, 2023 2:43 amI have three of them
I know I've made a couple dedicated threads about it too if you wanna search for them. One of them at least about removing the flipper tab. I also had some serrations cut into one and it was a disaster lol.
Re: The Sliverax
I bought someones de-flippered version. I'm not really a fan, but I might have liked it better if mine still had the flipper tab. Two things are for sure, it looks good and you will not slide up on to the blade. Very safe design in that respect.
Re: The Sliverax
The Sliverax is still currently in production and has not been discontinued, by the way.
- Nick
Re: The Sliverax
Well i guess that explains why dlt had them in stock! Good to see it is still in production. thx for the update
Good point on safety. I like flippers I cant imagine spending this much on a knife just to grind it down.JRinFL wrote: I bought someones de-flippered version. I'm not really a fan, but I might have liked it better if mine still had the flipper tab. Two things are for sure, it looks good and you will not slide up on to the blade. Very safe design in that respect.
Thanks! I will look for those posts. No way will I remove the filpper and thx for the head up on adding serrations. I personally feel like spyderco should add serrated versions for every model they produce. I love serrated and combo bladesEvil D wrote: I know I've made a couple dedicated threads about it too if you wanna search for them. One of them at least about removing the flipper tab. I also had some serrations cut into one and it was a disaster lol.
Re: The Sliverax
The Sliverax is one of my all-time favorite Spyderco models. I think it's a fantastic design. A buddy of mine ordered one for himself and he really likes it. I think it's one of the sleeper models that often gets overlooked. It carries well too
It's also not discontinued that I'm aware of. It's still in the catalog and available at the SFO
viewtopic.php?p=1294128#p1294128
Mine was fairly weak but so are a lot of other Taichung models. It's a pretty easy fix. Mine's really nice now and flips great
Re: The Sliverax
Regarding the detent, wouldn't it be easier to just add a little tension to the comp lock by bending it outward more, rather than drilling the detent hole a bit?
Re: The Sliverax
That might help a little but I think opening the hole and having the ball sit down inside a little more has a more positive effect. I've only ever tried to do the opposite on a frame lock knife that had a crazy strong detent and it didn't change much. I already had the tools I use to open the detent hole. It's a not brainer to do as long you assemble the knife and test as you go. The blade is hard so even with a diamond tool it takes some time to do by hand. I could use my drill press or rotary tool but prefer to do it by hand to prevent going too farImHereForTheMilitary2 wrote: ↑Wed Jul 26, 2023 6:32 pmRegarding the detent, wouldn't it be easier to just add a little tension to the comp lock by bending it outward more, rather than drilling the detent hole a bit?
BTW, my friend thinks the detent on his was fine and he's very mechanical (also a surgeon) and likes to tweak things to his liking. So not all will have a really weak detent. A while back I heard rumors that the Taichung plant was working on improving the detents on their models. Maybe the latest batches of Sliverax are better in that regard now
Also, I have no issue with the flipper tab hitting my finger. I've never really understood that. I guess my finger automatically moves out of the way because it's a non-issue for me. I could grind the tab off but I prefer to have it there
Re: The Sliverax
Same with me and my Yojumbo. It's amazing how many people can't learn to simply move their finger a quarter of an inch.Also, I have no issue with the flipper tab hitting my finger. I've never really understood that.
Re: The Sliverax
It's not a cheap knife.
I had very bad experience to disassemble my Manix 2 and Para 3 (soft screws,..).
It must be OK out of the box.
If I buy a Porsche it must be perfect.
If I buy a Dacia it can have some minor flaws.
Re: The Sliverax
None of the better models are inexpensive and, you're right, we shouldn't have to work on them to get them to our liking. I've adjusted pivots and made minor adjustments to several brand new knives.The light detents aren't optimal for a lot us but that's how they were coming. As I mentioned, I read one of the designers of one of the other collaboration models made in Taichung said they were working to improve detents. Hopefully they have and they're better now
Oh...BTW, people buy new Porsches and upgrade them all the time
