MT36P – K294 MICROCLEAN Mule Team Dropping Soon!
Re: MT36P – K294 MICROCLEAN Mule Team Dropping Soon!
I ultimately skipped this Mule. Looking forward to hearing what you think of it, Steeltoez.
Make Knife Grinds Thin Again.
I cut off the factory edge, and put 1 of my own. The burr cut off very easily from what I saw. The result was only 190 however I usually see a performance increase in more testing. I believe my 10V pm2 and Para 3 both hit 375 when it hit their peak. The magnacut I tested hits 350/360 so I'd like to see this k294 hit higher.
- VeraX_Knives
It should right? That's interesting. I'm not trying to.. constructive criticism? I think you're using the wrong testing material, because your cut numbers should never go up like that it's just not how physics works eh? So I know that you test with other things than sandpaper rolls, are the numbers any different there? Just to figure out if it's how you're sharpening or the material being cut. Getting a perfect edge is not an easy task and I'll be the first to admit that I don't go to.. the full potential of what I could because of laziness and "that'll do". You really should make a chart of your testing with different steels on different materials, that'll give you the most information in my personal opinion.Steeltoez83 wrote: ↑Wed May 22, 2024 7:45 amScreenshot_20240522_083100_Gallery.jpg
Also, how did you cut off the factory edge cause.. I'm guessing Spydercos heat treatments and if you got it decently hot you could see a pretty decent hardness drop. Just remember that you always want to do these high alloys under flood coolant if it's already heat treated.
••• You say E = mc² × I argue E² = m²c⁴ + p²c² •••
Jason Ward • shockey01@gmail.com • +1 412-726-8610 • My Discord
After 3 to 4 edges performance hits a plateau. Happens on every production folder I have ever tested. Sometimes happens on customs/midtech if I chose to cut test them or not. Most armchair quarterback reviewers read the script from the same fortune cookie anyways. Right now we haven't reached the peak performance just yet.
Cutting the edge off means swiping the apex across the stone. It creates a flat across the entire length of the edge. I use water on the stone as well as dipping the knife in a cup of water mixed with a few drops of dish soap.
I stick with a 1k edge for testing unless I'm trying to mythbust falsehoods I've read here. I only test my edges from the stone, no strops. Some steels/models I prefer with a different edge finish but I let the 1k be my standard.
- VeraX_Knives
That's kinda funny. I know what you mean by that I think. I've observed the same phenomenon but I've always thought that it's psychological because there's no real scientific explanation for it. I have to assume they're cutting under coolant and know their feed rates. That's pretty basic. I've also noticed that the one constant is that people who use stones that I know, get better edges than I do also as I'd expect. So why would this happen scientifically speaking? cubic carbides being abraded round? That should happen on edge 1-2? Right? So are they actually sharpening.. dry?. That's about all I can say here. You don't have a way of looking at the edge at least 500x (preferably 1000) I'm assuming? Cause we'd then be able to kinda see what's happening there exactly, not just guessing. I've never tested the edge of a production knife like this admittedly so in.. my testing everything is heat treated and cut by me so I know how it's being done. The only time it touches anything dry is in stropping and it's cutting jobs. They gotta primary grind wet but sharpen dry? It seems like*. IDK!Steeltoez83 wrote: ↑Wed May 22, 2024 6:06 pmAfter 3 to 4 edges performance hits a plateau. Happens on every production folder I have ever tested. Sometimes happens on customs/midtech if I chose to cut test them or not. Most armchair quarterback reviewers read the script from the same fortune cookie anyways. Right now we haven't reached the peak performance just yet.
I don't use strops for testing or my own personal carry. I have even been gifted free leather strops and compounds from Max aka stroppystuff. I have always endorsed that these would be the edge I would use and carry. With or without a blindfold I can get clean cuts across the grain on newspaper with a 1k edge. Larrin uses fixed angled systems for when he does his own catra machine testing. No idea what spyderco uses for their in house cut testing.
I did have a small cheap microscope thing for my laptop but I have no idea what black hole that fell into.
- VeraX_Knives
Larrin has Shawn do em actually I think. But yes, in general us nerds do use fixed angle types because.. we suck at the freehanding lmao I'll admit that one and... To quote Vince Lombardi... Have the knowledge to chase said perfection whilst knowing it's unattainable.Steeltoez83 wrote: ↑Thu May 23, 2024 3:29 pmI don't use strops for testing or my own personal carry. I have even been gifted free leather strops and compounds from Max aka stroppystuff. I have always endorsed that these would be the edge I would use and carry. With or without a blindfold I can get clean cuts across the grain on newspaper with a 1k edge. Larrin uses fixed angled systems for when he does his own catra machine testing. No idea what spyderco uses for their in house cut testing.
I see people daily who think they know what they're doing just because someone else told em it's right or didn't know that another procedure was possible (medical doctors). I don't personally go to any that won't say oh ya we don't actually know anything about the body because we don't relatively. Period done fact. Next.
Instead I just get the people that I know and trust to the extent that any human being can be. It would be like me saying that I know why you got that result or how you test or something like that. I just don't lol. Doesn't mean that I can't try and figure out the same question
- VeraX_Knives
And yeah, I do unfortunately mean daily there.
Y'all wonder why I'm so miserable
Shawn I believed did the catra coupons. I'm not sure he did everything for Larrin. My backyard bro science is more flexible. I let larrin do his thing, and I do mine. There's many in this hobby who use fixed systems like hapstone, kme, wicked edge etc who get great results. To me that's better suited for published literature than mine.
- VeraX_Knives
Yeah same here - I'm not sure about anything with those twoSteeltoez83 wrote: ↑Thu May 23, 2024 8:40 pmShawn I believed did the catra coupons. I'm not sure he did everything for Larrin. My backyard bro science is more flexible. I let larrin do his thing, and I do mine. There's many in this hobby who use fixed systems like hapstone, kme, wicked edge etc who get great results. To me that's better suited for published literature than mine.
Im.. not a trustworthy person with human beings hah. Couldn't agree more man. But I do have to unfortunately say that.. well let's put it this way.
I absolutely despised every second of my life that I.. won't use the term wasted? But "wasted" (almost that) with grad school. It was absolutely abysmal. The other students. The teachers. The drive. The atmosphere. The freaking smell (literally). It's the biggest waste of money and time in my life. Period end of discussion. Now does it open up job opportunities that I have not used? Technically speaking sure I suppose but I'd have to add that it's not the knowledge you're hiring it's the person ultimately. And yeah, I have to kinda admit that once.. once you know this stuff? It really does just... Carry over to anything everyday stuff from cooking to.... It's chemistry and physics so whatever else I cannot think of that covers those topics - medicine I forgot about - and you really.. do learn the hard way that okay so I'm using myself as an instance here. I have to have a tooth removed (should* -it's root canaled so perfectly fine I know this) so when I was looking for oral surgeons - I would ask them literally made up questions and also a mix of real ones to show them that I have knowledge, just to see what they actually knew about a certain subject and then say ya no thanks sorry I'm good. It's not like I don't have lidocaine/epinephrine exactly as they use it cause that's where I stole it from Thanks! If I could properly.. articulate my body to work on tooth #2 I'd have already done it myself. I'm that type of person. Take it or leave it.
This is psychology and sociology. My real specialty lol
Main point being that knowledge is.. money which is freedom. Simply put nothing more or less there. I don't have to rely on anyone. Period. For support if necessary I have my family and friends, but I'm pretty good at the compartmentalizing and not caring what happens in this world anymore. Yes I'm well aware how lucky I am for this. And remember that I work with computers hahaha.. not physics or anything. That's even more depressing but the truth.
If your paying for someone's "expert" knowledge or skill set it's human nature to be suspicious. In my walk with faith I understand everyone has their own cross to carry. I am who I am from carrying my own. I sometimes need to sit back and recognize others travel different terrains when they carry their own crosses. I always tell my daughter who's in med school currently that the ability to translate the information is a skill she can always improve. Whether she encounters the patients with blind faith or the ones who question everything they think of.
- VeraX_Knives
I think? That you know my religious perspective but I don't know if you read that cause it was in a pm to Kristi. I'm not.. necessarily by the book religious. I can't.. square what I know about human behavior and how "historical texts" are normally interpreted. I put historical in quotes cause while we're both smart enough to get the victors make history not the losing side. But I can only with my human brain.. possibly understand the concept of a quote unquote "higher being". Whatever your definition of that one is. Mine being pretty basic - philosophy and intuitively based - I know that I ain't God and that there's something REAL that our brains I don't believe are able to comprehend frankly. At least at this stage of evolution which I'm surprised we made it to. We named ourselves homo sapien sapiens. It means I believe man, wise, wise. We literally named ourselves scientifically doubly wise which I howl at.Steeltoez83 wrote: ↑Fri May 24, 2024 8:13 amIf your paying for someone's "expert" knowledge or skill set it's human nature to be suspicious. In my walk with faith I understand everyone has their own cross to carry. I am who I am from carrying my own. I sometimes need to sit back and recognize others travel different terrains when they carry their own crosses. I always tell my daughter who's in med school currently that the ability to translate the information is a skill she can always improve. Whether she encounters the patients with blind faith or the ones who question everything they think of.
Other than that stuff? Because of my beliefs it.. precludes me from really thinking about it much. So in return, considering my life circumstances, I'm a pretty happy guy as much as I know that doesn't come out over text lol.
The only thing that I could possibly say here and I don't have a daughter lol thank God himself for that one, but as a guy who was going to go to pre-med and then neurology or internal medicine but had a kid, I did end up teaching myself what I wanted to learn with medicine. Main point as a dad to dad? You already know this. But some of the younger girls I know that are RNs.. have a real difficult time with it. I could never practice medicine because I know too much and you can't unknow it. And I don't want someone's life in my hands, ideally speaking. That's kinda what I was talking about with like... say school?. I did learn some things with chemistry obviously although I am VERY FAR from an organic chem .. amateur even. But the basics, once you "get" it. It literally covers everything in life. Kids. Psychology. Marriage. Money. Work. Cars. Taxes. Houses. I've had many professionals who have not been able to answer questions of mine on houses that I didn't buy! The one I bought I actually learned the former owner was an engineer so it makes sense! Lol. And that was really my only point there, is that as much as I will sit here until my death bed and tell you that schooling isn't worth it. It just isn't. Unless! You are the type of person that needs in person instruction. All I, me, gotta do is ask a few "why this why that is it what I think okay it is or no it isn't" and I just get it. People have asked me how I do not know just as I do not know why I can drive how I can. I just do it. Lol. Such an annoying question.
The medical field as I'm sure you well know is a literal joke. So is the schooling frankly that your daughter is getting. She could be going to UPenn it's not going to matter. I'm married to and friends with a few medical doctors. I can honestly say that.. I wouldn't trust my own wife to do this stuff. I have to do it. If I F up - it's on me - not someone else. As the last liberal idiot dentist tried to say that there's no guarantees in life and I then replied well doc I guarantee you that I am walking out of here, was a pleasure meeting you. His face. Utterly priceless. And oh yes I get a kick out of screwing with stupid people, *to a point*, I'll admit that. I'm human. Period. Sue me. (Ya no don't do that haha).
I always try to.. explain "religion" to my generation and younger the way that I just did. I find that in my experience, it actually usually.. works as a foothold rather well if.. you have one that says OH I'm not religious. That's my go-to lol.
On the communication with your daughter - idk really what to say. I can tell someone's intentions and thoughts.. within 2 minutes of meeting them. I ran a dating advice website and whatnot I study people so. I mean IDK you said something that made it seem like we may be similar lol. I never used to bother explaining things to people but eh. I got old and I honestly realized just how little people actually know in this world today. I'm a jack of all trades master of none, maybe if anything PCs people and physics, but it's not like I... Can't run heavy equipment or do manual labor I been there done that but it's so specialized these days that.. you get literally complete morons. Sure someone may be able to tell me... Exactly how a organic chemistry synthesis works. I do know the Krebs cycle. I can tell you that. I can not actually explain why it's doing what it's doing, besides processing citric acid, cause I just ain't that smart with chemistry I hate it. Physics is easy. Numbers I like. Layering numbers 5,000 times is still 0-9. Layering chemical synthesis and saying that I actually understand why every part of it?
I'm sorry sir I just cannot do that one.
I can however explain why if you took two knives into space they would stick together. It's to me like an entirely different.. way of thinking almost?.
As a kid my daughter always digested knowledge faster than others. She received awards and accolades bcuz she was the smartest in her grade. She would tutor others bcuz she has a way of helping others understand what they couldn't. She has the intelligence to persue many different career paths. She wants to help people thru a career in the medical field. She's wanted this since she was around 8 or 9 years old. I'm extremely proud of my daughter and the path she is on. I know there are going to be bumps in the road, I have my own friends within hospitals and other pharmaceutical companies. She's doing this without any help, and I'm proud of her.
The next testing edge on my mule achieved a score of 290.
- VeraX_Knives
So is that 100 rolls more? I just don't know whether to say that the testing material is "sharpening" your knife or, what seems more plausible to me, is that they literally hot sharpen these things for time reasons. Not a decision I'd make but. That's why I'm not the CEO of a company
Yo Toez, from what I remember k294 was a bit of a pain to deburr after each progression(compared to the T15 & 15V mules I did around the same time). Could have a cpl multiple factors that went in to it but figured I'd just toss it out there. Also, hope the lady is recovering well.Steeltoez83 wrote: ↑Wed May 22, 2024 7:45 amScreenshot_20240522_083100_Gallery.jpg
My lady is with God now. She was too eager to start being much more independent than she was capable of. She slipped in the bathroom and hit her head. She fought back for almost 2 weeks but it was too much. I dont dwell on the tragedy, I focus on the extra time I got to have her.tcarltonw wrote: ↑Tue May 28, 2024 10:57 amYo Toez, from what I remember k294 was a bit of a pain to deburr after each progression(compared to the T15 & 15V mules I did around the same time). Could have a cpl multiple factors that went in to it but figured I'd just toss it out there. Also, hope the lady is recovering well.Steeltoez83 wrote: ↑Wed May 22, 2024 7:45 amScreenshot_20240522_083100_Gallery.jpg
I only used the shaman and the manix in 15V for my testing. I never experienced any issue with burr removal with k390, k294, or 15V. I haven't gotten to the T15 mule yet. Been shopping for cars with my daughter. After 1k I don't form any burrs. I would refine further on a loaded leather strop alternating passes at that point. Plus I only remove the burr on my final stone. Removing it at every stone is not a routine I personally do.
- VeraX_Knives
Obviously not much I can say besides that's horrible news I'm extremely sorry to hear that man.
[quote=Steeltoez83 post_id=1784765 time=1716994495 user_id=1004915
[/quote]
I'm sorry for your loss.
Be well.
[/quote]
Be well.
- VeraX_Knives
I'm pretty sure that I can speak for anyone here that - I'm not entirely sure who here knows the details behind all of that but - we're here if ya need someone to talk to, especially myself. I can only really speak for myself, but ya that wasn't the.. ideal news for me to get at 530pm with our recent conversations and whatnot. No I don't know you or her but it's just.. depressing news and as the resident psychology/sociology guy I only have a slight idea about what you're going through man cause I myself - my first response was "you're kidding" then "ah f me" and then "if I was her id probably have done the same thing" and then the "oh Christ her ****** daughter" and you. Was making dinner and just lost my appetite. Then I had to put myself in her shoes and I cannot say that.. if that happened to me that I would change... My risk assessments. It's not her or me it's just how the human brain works. And I know that well. If I were you I'd be quite a mess. I'm incredibly sorry for your daughter that's just.. I don't care if it blanks it out it's fucked up.
You have all of my contact information. I had an idea of setting up a GoFundMe or something similar but I am well aware that you are not thinking... About ANY of that bullshit right now. If there's anything I can do to help - consider it done and while I believe that you are not the type of person - this is different - and yeah I can't do much but monetary assistance.. is a real thing we'd have to talk about. I know anything that I say is entirely useless unfortunately.
Talk about the short straw. Now ya, we both know that others have it worse yada yada it's relativity and I'm assuming you think that same way but. This time I believe that it actually is a proper.. comment.
Take care brother, we're only human beings we can't expect to understand this stuff. In my opinion*. I had to stop asking myself "why" a long time ago. In order to stay sane.
-Jas
Thankyou for the kind words. My Alice was a very special person. She brought out the best in me. Id go on a religious rant here, but that's frowned upon. Sometimes life throws you lemons sometimes it throws the whole tree at you. My strong foundation in faith is helping me to cope. The song "born bold" by valley of wolves has been my jam of late. Right now I'm carrying my cross the best I can. I won't accept any donations or gofundme or anything like that. I'd forward it to cancer research anyways, melanoma to be specific. I am taking some time away from cut testing tho. I have been thinking about getting into running again this summer to distract myself. Dwelling in negativity is like swimming in quicksand.
