Page 1 of 2
Z-12 Ultra mule?
Posted: Fri Sep 12, 2025 12:45 pm
by Skidoosh
I'm in the process of putting a handle on my Z-max mule (I'm a bit behind) and was wondering why z-max hasn't been around much. Then I saw Cedric's post on zapp z12 Ultra. Sal, any chance of a taste this stuff? It sounds right up Spyderco's alley.
Re: Z-12 Ultra mule?
Posted: Fri Sep 12, 2025 3:35 pm
by weeping minora
Sounds interesting for sure. I'd be in for a taste.
Posted: Sun Sep 14, 2025 11:53 am
by Pacu0420
Just watched Pete (Cedric and Ada) do a cut test with Z12 Ultra. 1300 cuts through sisal rope.
Ummm...Yes please!!!
Posted: Sun Sep 14, 2025 12:15 pm
by horzuff
Also saw the video, the steel looks really interesting. But it must be something new as it's not even on zknives yet
Posted: Mon Sep 29, 2025 12:06 pm
by WilliamMunny
With crucible now closed I wonder if Z-Wear will replace Cruwear.
Posted: Fri Oct 03, 2025 5:41 pm
by Skidoosh
You still have carpenter making PD1- another mule that lingered around for a long, long time. I love mine but it will be interesting to see what happens.
Posted: Wed Oct 08, 2025 4:57 pm
by B12buddy
WilliamMunny wrote: ↑Mon Sep 29, 2025 12:06 pm
“Z” in Z-Wear stands for Zapp. Zapp has no melting capabilities. Anytime you see a Z grade it was produced by someone else and rebranded. If you purchased Z-Wear, it might have been Cru-Wear but it also might have been from any other source.
Posted: Fri Oct 10, 2025 9:33 am
by standy99
Double Z in the Reveal 19…… ; )
Posted: Fri Oct 10, 2025 9:45 am
by Skidoosh
YES! I'm excited to see this.
Z-wear was previously released as a PE mule, interesting to see a SE mule released.
Posted: Fri Oct 10, 2025 9:55 am
by WilliamMunny
Skidoosh wrote: ↑Fri Oct 10, 2025 9:45 am
They are also kind of re-releasing Z-Wear in PE but as Z-Wear BQ, not sure what the difference is. It should make a nice SE blade due to it's toughness.
Posted: Fri Oct 10, 2025 1:35 pm
by Gears_QQQ
What kind of steel are we talking about? I'm not very familiar with it. Is Z-12 steel?
Posted: Fri Oct 10, 2025 3:28 pm
by cjk
Zapp "Blade Quality" knife steels. I think that this mainly means that they're grades that they already sell which have been annealed and hot rolled into sheets. This PDF has compositions in it for both "Z-Wear BQ" and "Z-12Ultra BQ".
https://www.zapp.com/fileadmin/_documen ... ard-US.pdf
Posted: Fri Oct 10, 2025 3:30 pm
by cjk
Posted: Fri Oct 10, 2025 6:33 pm
by Skidoosh
What does BQ stand for?
Posted: Fri Oct 10, 2025 7:07 pm
by RustyIron
Skidoosh wrote: ↑Fri Oct 10, 2025 6:33 pm
Posted: Sat Oct 11, 2025 4:26 am
by Gears_QQQ
cjk wrote: ↑Fri Oct 10, 2025 3:28 pm
Thank you. Interesting and extensive information
Posted: Sat Oct 11, 2025 1:04 pm
by sal
We'll certainly want to hear your experiences with the material. Little is known about it. the numbers give some information, lab tests give some information, but there is nothing like RWT (Real World Testing).
Posted: Mon Oct 13, 2025 9:13 pm
by Bolster
They left out a "B." It's a steel specifically formulated for barbecuing.
Looks like ZWBQ is a marginally balanced steel, favoring toughness over edge retention; Z12UBQ not a balanced steel, greatly favoring edge retention.
Posted: Thu Oct 16, 2025 7:56 pm
by Skidoosh
Z-M4 PM looks interesting too
Posted: Fri Oct 17, 2025 2:27 am
by horzuff
Skidoosh wrote: ↑Thu Oct 16, 2025 7:56 pm
That's just PM M4, so the same as CPM-M4 :)
