Super Wood. A wood that can be a knife?
Fireman
Post by Fireman »
This is quite interesting. You can make a wood knife blade but perhaps start with scales made from this.
50% stronger tensile strength than steel at half the cost and 80% lighter. 😳 it’s basically a new kind of Kevlar and retains the beauty of wood.
Mule Team Army 001 (patched)
MNOSD 008 :usflag
weeping minora
Re: Super Wood. A wood that can be a knife?
Post by weeping minora »
Certainly interesting.
I hope sharpening doesn't require diamond-toothed chainsaws :flushed :grin-sweat
Make Knife Grinds Thin Again.
Hmm, time to upgrade the Spyderco Wooden Knife Kit :thinking
Stuart Ackerman
Post by Stuart Ackerman »
Pakkawood Dymondwood Laserwood Pimarli Jabroc etc:
ALL fit into the category of a compressed wood. And phenolic resin to boot...
I have a lot of 30mm and 20mm Pakkawood and Jabroc
At 10 metres:
A .38 Special from a 4 inch Ruger Security Six do not go through the 30mm, but stops short about 3mm from the other side.
A .22LR from a Browning Match 150 does not go through the 20mm, about halfway.
Just so you know...
But a knife blade? Hmmmm, maybe not so sure.
I am curious to see where this super wood idea goes.
Larrin
Post by Larrin »
I already wrote about these people three years ago: https://knifesteelnerds.com/2022/04/14/ ... poiler-no/
It’s not stronger than steel, it isn’t a “new Kevlar.” It’s not even clear if their process is any better than previous densified woods.
RustyIron
Post by RustyIron »
No thanks.
If I want plastic scales, give me FRN or G10, and in a color that I find appealing. If want wood scales, want the natural, authentic look of real wood. I value the wabi-sabi of a knife that is truly mine. Fake wood reminds me of the paint job on a 1975 Ford Country Squire station wagon.
Post by Doc Dan »
That sounds almost too good to be true. It would be wonderful if it was true.
No Mule requests please.
Fireman
Post by Fireman »
RustyIron wrote:
Mon Sep 01, 2025 6:26 am
No thanks.
It IS real wood. It’s just 1/5 the original size
MNOSD 008 :usflag
Scandi Grind
Post by Scandi Grind »
A knife needs wear resistance. This isn't gonna have that even if it is tough. Handles, sure. Blades, nopey.
-- Old Norse proverb
Fireman
Post by Fireman »
I want a cane made from this. And golf clubs
MNOSD 008 :usflag
Stuart Ackerman
Larrin wrote:
Mon Sep 01, 2025 4:46 am
Thanks for that Larrin. :smiling-cheeks
Yup, hype has sold a lot of things. I guess?
Danke
Post by Danke »
But how bout' a little something for MBC that leaves your target full of splinters. That might be fun.
Fireman
Post by Fireman »
Not sure if that’s the same method and company Dr. Larrin. I’ll have to look. Something I found interesting was they are making nails out of this material. That should be great for expansion issues and corrosion. They work in nail guns too.
MNOSD 008 :usflag
SchoonerBum
Post by SchoonerBum »
It’s fascinating how technology runs in circles sometimes. Trunnels (tree nails) predate iron nails by several millennia and are still used occasionally for boatbuilding, and I’m sure for other specialist uses.
I love the concept of “appropriate technology:” It’s not high or low tech, but what’s most appropriate for the task at hand. It is quite possible to get a wicked sharp edge on, for example, a wooden arrowhead, but the edge will only be good for one shot. 🤷‍♂️
Fireman
Post by Fireman »
Off topic but I want a baseball bat made of this stuff. That would be amazing
MNOSD 008 :usflag
Scandi Grind
Fireman wrote:
Thu Sep 04, 2025 11:20 am
I wonder how heavy it would be? It is much denser than wood I assume, but we have seen polypropylene bats before, so it could be sort of like that.
Stuart Ackerman
sal wrote:
Mon Sep 01, 2025 9:47 am
imagine a knife with wood blade and stainless steel scales...? :cheap-sunglasses
Stuart Ackerman
Call it the woodWORKER... ?
Fireman
Post by Fireman »
Scandi Grind wrote:
Thu Sep 04, 2025 12:46 pm
A bat that won’t break is appealing. Especially a self defense bat
MNOSD 008 :usflag
