Page 1 of 1
Serrated K390 sharpening?
Posted: Tue Jun 10, 2025 9:00 am
by S-3 ranch
Just ordered a serrated k390 endela , any suggestions on how to sharpen it after I put some hard use on it, I have my process & tools for vg10 serrated, but I think K390 serrated will be a different beast? Does it have to have diamond equipment?
Re: Serrated K390 sharpening?
Posted: Tue Jun 10, 2025 9:45 am
by JayHenMac
Use a Sharpmaker with CBN rods. K390 just takes a little more work, but I don't have any issues keeping my SE K390 sharp using the method Sal teaches in the product video for the Sharpmaker.
Posted: Tue Jun 10, 2025 10:36 am
by RustyIron
What Jay said.
Generally, I use the regular Sharpmaker rods because they're gentler on the serrations. Occasionally I'll use the diamond rods, but they're rather aggressive.
I don't use Sal's method. Rather than hold the blade vertically, on the ground side, I tip the blade to match the factory grind. On the flat side, I tip the blade just a skosh past the factory grind so I'm still hitting the edge, but not scratching up the whole side of the blade.
Posted: Tue Jun 10, 2025 10:50 am
by Palestrina
RustyIron wrote: ↑Tue Jun 10, 2025 10:36 am
What Jay said.
I'm holding the blade vertically on the ground side, but sharpen the back side the same way as you do.
I just needed the CBN rods once to repair a small chip, other than that - as you said - the brown and white stones are sufficient to keep K390 SE sharp.
Posted: Tue Jun 10, 2025 9:17 pm
by blueblur
I’ve had great success sharpening se k390 with the medium and fine sharpmaker rods.
Posted: Tue Jun 10, 2025 10:00 pm
by Bill1170
Yes, brown and white rods for maintenance, diamond or CBN for damage repair and reprofiling.
Posted: Wed Jun 11, 2025 4:06 am
by Evil D
Bill1170 wrote: ↑Tue Jun 10, 2025 10:00 pm
This is the way.
Also the more you stay on top of touchups the less you'll ever need anything more course until/unless you damage the edge.
