Spear Point vs Leaf Shape?
SpyderEdgeForever
Post by SpyderEdgeForever »
What do you all think of the spear point blade shape? Is it a variation of the leaf shape? What do you say, sal? I am convinced that the strongest, toughest blade shape is the convex apple seed ground leaf or spear point. If made of a good steel with a good heat treatment those two shapes will win over even the drop point and clip points, scimitar points, stiletto point, and would only be equalled by the tanto and possibly wharncliffe.
Curvature. I was personally inside a canvas tipi, hand sewn and well anchored to the ground during a tornado. The winds hit the conical curve and flowed around the sides, pressing it firmly to the ground. Had it been a box shaped house it would be splinters. Same thing.
Re: Spear Point vs Leaf Shape?
Hi SEF,
Spear points (symmetrical) and leaf shape blades have been around for about 40-60 thousand years. The materials have changed: wood, stone, metal, etc., but the basic shape is not new.
"Continual improvement is our evolutionary obligation to humankind".
Zero Wolf (the bad dude from the move Apocalypto) had this nice spear/leaf-shaped dagger...I think it's a precursor to the Bodacious, isn't it?
zhyla
Post by zhyla »
SpyderEdgeForever wrote:
Sat Apr 26, 2025 4:06 pm
This is problematic in a several different ways.
First, discussing a shape without the actual geometry is "point" less.
Second, the spear point, if we're actually talking about the true spear point with the false edge, is inherently weaker than a drop point if made from the same stock. You can't remove material and come out ahead in strength.
Third, tip stability only really matters to the degree that people do dumb stuff with their knives. No combination of point shape and steel type will last long as a screwdriver unless you have screwdriver geometry. Fix the user and you magically increase you tip toughness by 1000%.
Whatever this is classified as.
twinboysdad
Post by twinboysdad »
Leaf is the best utility shape for general use. You get the tip of a Wharn with enough belly to use. Leaf Manbug improved the original by a large margin
Tristan_david2001
Post by Tristan_david2001 »
I agree the spyderco leaf is the most functional general utility cutting tool shape, the differences between a spear and leaf I’ve gathered is spears are symmetrically curved on the edge side and spine side. Whereas the Spyderco leaf have varying differences of edge belly in relation to the spine, and usually are dropped down at a negative angle from the handle for better leverage in the cut, and positions the point straight forward aiding in a strike if needed to be used that way. My favorite leafs?/leaves are the calypsos calys, kopa, and temperance lines
:bug-red-white:
SpyderEdgeForever
zhyla wrote:
Mon Apr 28, 2025 10:04 am
Thank you for this, zhyla. So here is my desire put a different way. What combination of steel, geometry, blade shape, and blade thickness all combine to give me the perfect general use knife?
I want for everyday use like breaking down cardboard boxes, making sandwiches, cutting string, and God forbid fighting off a rabid kangaroo if necessary. I am leaning towards a Spyderco Tanto Endura 4 or Calypso Lightweight with combo edge and FRN scales and 3.5 inch blade.
StuntZombie
Post by StuntZombie »
Neither of those knives exist, so what’s it matter? If you’re playing pretend, you can just make up a steel for this hypothetical use and be happy.
This analogy makes less than no sense.
Chris
Bill1170
Post by Bill1170 »
I agree about fixing the user. A bit of informed care goes a long way towards making things last. I enjoy my knives with fine tips and they last because I respect them and treat them with care.
SpyderEdgeForever
Bill and zhyla and Stunt Zombie and others, Yeah I don't want to drop the brand names but to my surprise recently I've heard people criticize Spyderco for having "fragile tips and points", compared to some other famous knife brands. This surprised me because most of you as well as myself have not had a Spyderco tip break. My Enduras have gone through tough cardboard, hard bread, and plastic bubble packaging with ease. One guy said he stabs open steel paint cans with knives. I have seen older pre Endura 4s with broken points.
Jesla
Post by Jesla »
Mon May 12, 2025 2:37 pm
…..My Enduras have gone through tough cardboard, hard bread, and plastic bubble packaging with ease. One guy said he stabs open steel paint cans with knives….
Seriously… cardboard, hard bread, and plastic bubble wrap….. that is light use… very light. Steel paint cans…. Never seen “steel” paint cans, but I stab metal cans all the time. All I have ever seen is a dulling of the edge that actually contacts the can, no tip breakage.
I often wonder if you stay up at night thinking some of this stuff up, it’s bizarre… I guess you are not old enough to remember when beer cans had no pull tabs… knives were often used for this when a can opener wasn’t available. Only blade I have that I would not do this with is my ceramic blade which is basically glass.
Still plays with knives…
SpyderEdgeForever
Jesla wrote:
Mon May 12, 2025 6:06 pm
Endura 4 can do that I believe.
apollo
Post by apollo »
The gen 3 endura's had a very fine Needle tip. Gen 4 completely changed the design. So its possible for earlier endura's tips to breal but you need to be a brute to do so.
I must say, I am gaining an appreciation for straight back blades with more or less full thickness points, because they give you a really strong tip that still comes to a pretty fine point so they still pierce well but aren't nearly as fragile. This also comes with more belly and upswept blade tip than I like so it's a tradeoff. Microtech do this a lot with their single edge OTF's and I like it a lot despite not liking a lot of belly.
SpyderEdgeForever
Evil D wrote:
Thu May 15, 2025 8:15 am
You and me both though no Microtechs here.
Netherend
Post by Netherend »
Evil D wrote:
Mon Apr 28, 2025 10:43 am
Agreed. The Bodacious blade shape performs so darn well…
Just one more knife...
SpyderEdgeForever
Netherend wrote:
Wed May 21, 2025 11:04 am
Beautiful, practical knife. Would you say you prefer the plain edge because it cuts smoother than if that were serrated, on that leaf shape?
Netherend
Post by Netherend »
Sat May 24, 2025 6:49 am
I generally prefer plain edged blades for their ease of maintenance and predictable cuts on plant matter .
I do like serrations for cutting garden hoses.
SpyderEdgeForever
Netherend wrote:
Sat May 31, 2025 6:09 pm
Thank you, I value your insight.
