Swapped my scales late last night and, this is on me, put off using loc-tite on the pivot.
Left the house with the pivot dialed perfectly. Just barely enough tightness to prevent a free swinging blade.
Use the knife a couple of times and notice it's now free swinging and there's generous side to side play.
Use the knife a few more times and realize I either need to stop carrying it for the day or go buy a torx set for until I get home.
You see, this is exactly how I cut myself on a tip up compression lock before.
Para 2 had the same issue. I had even used loctite on that knife but I guess the seal broke.
Pivot worked itself loose. Compression lock detent depends on the pivot screw tightness to function correctly. Loose pivot meant there was barely any tension on the detent. Knife came open in my pocket and sliced my hand.
I don't understand why this happens. I know I can fix the issue with loctite, which is why I bought some on my lunch break, but I don't run into this issue with any other knife. Not any other brand. Just Spyderco.
I carried a different brand the last few nights. I took it apart, cleaned and lubed it, sharpened it etc. before I carried it those few days. No loctite on the pivot. The pivot tightness is exactly where I set it a few days later.
Why can other brands hold the pivot tightness with no loctite for weeks but Spydercos loosen themselves after 20 openings?
Is this something that could be remedied by using different types of pivot screws?
It just seems silly having to worry about slicing my hand open at work over a pivot screw. There has to be a better way than being forced to loc tite the pivot screw any time an adjustment is made.
This has happened to me with the Military 1, Military 2, Para 2, Police 4 and more.
