Spyderco's Rex 121 factory blade protection
sfunkb
Post by sfunkb »
I just purchased a Spyderco in Rex 121. I was wondering if anyone knew POSITIVELY what Spyderco uses on the blade to protect it before shipping, since Rex 121 is well known for low corrosion resistance. Please, NO SUGGESTIONS, just EXACTLY what Spyderco uses.
Thank you.
TazKristi
Re: Spyderco's Rex 121 factory blade protection
Post by TazKristi »
sfunkb wrote:
Wed Dec 04, 2024 9:54 am
Thank you.
Hi, sfunkb:
Welcome to our forum. Knives with tool steel (like REX 121) have a desiccant pack included in the box.
We hope you enjoy your time with us.
Kristi
sfunkb
Post by sfunkb »
TazKristi wrote:
Wed Dec 04, 2024 10:51 am
Hi, sfunkb:
Kristi
Thanks Kristi (and thanks for the welcome!). I'm aware of that. But what I was asking is what lubricant or protectant they apply to the blades to prevent rust before shipping them from the factory. (I would like to begin using the same lubricant/protectant.)
zhyla
Post by zhyla »
Ha. The answer is apparently nothing. Enjoy your blade!
bdblue
Post by bdblue »
zhyla wrote:
Wed Dec 04, 2024 5:39 pm
I would think any product they are likely to use would be evident when the knife was taken out of the box and I've never noticed anything like that.
Some products you can spray on then wipe off but that would take a lot of time during the packing of each knife and there would likely still be some evidence of it.
JBoone
Post by JBoone »
I have had at least one spyderco tool steel knife come new with some type of lube. Noticeably in pivot area/base of blade. I think it may have been the Rex 121 (or the Hap40 satin mainix?). Both were purchased during similar timeframe. Somebody tell me I am not crazy?
Edit: is it possible dealer may have done prior to shipping?
dullmaker
Post by dullmaker »
JBoone wrote:
Wed Dec 04, 2024 8:58 pm
I just unboxed a Rex 121 Lightweight Sage 5. I definitely wiped off some type of oil/lubricant from the blade. A desiccant packet was in the plastic with the knife as well.
Bruce
gimibala
Post by gimibala »
It doesn't matter what Spyderco applies to the blade before shipping. What really matters is how you protect and care for the blade the moment you receive the knife. I personally use Ballistol on all my knives. In fact, I just applied some to my Rex 121 right now.
sfunkb
Post by sfunkb »
Thanks to all for the replies.
ZHYLA, and others that are uncertain if Spyderco applies something on the blades before shipping, the answer is ABSOLUTELY. I know because I have 17 Spydercos purchased from various vendors and each has come with some light oil or other substance on the blade. I generally wipe it off and apply Ballistol, which over the years (40+) that I have been collecting knives, I've found works the best to prevent blade rust.
I was simply trying to find out what Spyderco uses, and if they use anything "special" on Rex 121.
Thanks again.
GarageBoy
Post by GarageBoy »
I'm curious if it's applied by the factory or by Spyderco
Cletus
Post by Cletus »
I wax mine with Renaissance wax, as I do most of my blades except for DLC. Never a problem with rust. Rex 121 does not seem to want to rust much anyway, not like Maxamet or k390.
Albertaboyscott
Post by Albertaboyscott »
Spyderoil
Albertaboyscott wrote:
Thu Dec 05, 2024 4:21 pm
Spyderoil
:index-finger Good one!
I've bought more than my share of Spyderco knives and I know that most, if not all, have some kind of protectant on the blade. Whether or not Spyderco will divulge what they use is the question
Soban
Post by Soban »
Definitely some sort of thiiick oil as mine arrived yesterday and I had to wipe a glob of it off. Was different than whatever they add on the seki factory though. That blade was soaked.
The stainless blades I received also had a thinner coat of oil on them but enough that I could see fibers sticking to the blade.
zhyla
Post by zhyla »
I just going a Spyderco (Taiwan) and it had a thin coat of oil.
Spydie Juice!!!
Zive
Post by Zive »
This topic has come up in the past and seems to be a trade secret based on threads I’ve read. This is supported by Kristi’s response about desiccant and not the actual coating agent.
It may be in Spyderco’s interest not to divulge the exact coating agent to help with counterfeit detection (blades coated with something other than what their factories use). Have wondered the same thing though…
weeping minora
Post by weeping minora »
Zive wrote:
Fri Dec 06, 2024 9:27 pm
Excellent point.
Make Knife Grinds Thin Again.
