You get these horrible scenes that you can't unsee.
The victims, a St Nick's Chief and a MagnaCut Salt:
Unfortunately for some reason I couldn't get the Salt lock bar pivot pin to fit into the St Nick's lock bar so I couldn't assemble them together at the same time. The lock bar on the Chief is actually a bit longer in the back than the Salt so it couldn't be assembled into the Salt handle.
Don't laugh he ran out of hot water.
Ok so that's actually practical. It will close properly and the blade doesn't hit anything inside just like it normally should. If you really wanted a full size handle but maybe are limited by blade length laws, this could be a real thing.
Then there's this monstrosity..
0/10, can not recommend. Can't decide if tip up is worse than tip down or visa versa.
I'm sorry for this thread but now I can't undo it
