How to Rit Dye Native 5 Salt Dark green?
Ruudr
Post by Ruudr »
Hi,
What kind of color Rit Dye can I use to give my Native 5 Salt in Magnacut a dark green color?
Shall I use hot water? Any additives?
Maybe you have a picture if you’ve done it yourself?
Best,
Ruud
Windward
Re: How to Rit Dye Native 5 Salt Dark green?
Post by Windward »
Last yellow handle i did to dark green was 3 parts peacock green to 1 part navy dyemore. Splash of vinegar at about 200 degrees. Dunked it and checked every few mins
phaust
Post by phaust »
Straight up black synthetic turned my Pacific Salt 2 and Salt 2 a dark green. Overcast right now so kind of hard to get pics, but the base must be blue/green for that
This is the same dye with less time in the pot and after it faded some (the pics above are after redyeing)
ZrowsN1s
Post by ZrowsN1s »
You get a nice 70's lime green with a quick dunk in Tropical Teal rit dye. Longer will get you a darker green.
These are both done with tropical teal. You can see spots of the teal color on the paper towel. The Dfly was just a few seconds, the endura was 30 seconds +. Just keep dunking until it's dark enough.
I used 6 parts water 1 part dye, bring to a boil and then turn to low heat/simmer. Dunk for 5 - 10 seconds at a time, checking the color as you go. I rinsed in cool water in between dunks.
Ruudr
Post by Ruudr »
Thanks for the info! I try to get an olive drab color. So maybe I’m going to mix a bit of brown with green Rit Dye.
MidnightCoalCo.
Post by MidnightCoalCo. »
Ruudr wrote:
Sat Jun 29, 2024 11:51 am
Is this the kind of OD Green you are trying to get?
:bug-red-white Spyderco enthusiast with way too many to list. :bug-red-white
Ruudr
Post by Ruudr »
MidnightCoalCo. wrote:
Sat Jun 29, 2024 12:11 pm
Yes that’s the exact color I try to get!
What colors Rit Dye did you use? And is the back lock black?
MidnightCoalCo.
Ruudr wrote:
Sat Jun 29, 2024 2:03 pm
Below is everything I did to get this OD Green color, the back lock is the standard satin color, I think the shadows from the picture are making it look black but it isn't.
So this is actually a mix of three different Rit Dyes that is suppose to be "Moss Green" but if left in long enough you get a nice OD Green. You will need Apple Green, Dark Green, and Dark Brown. I took a small/medium sized pot and put 4 cups of water, 1 cup white vinegar, one squirt of dish soap (not sure if it does anything), 1 tablespoon of Apple Green, 1/2 tablespoon of Dark Green, 1/2 tablespoon of Dark Brown. Once it heated to a low boil I soaked the knife for 3 minutes total, checking it every 30 seconds to see if the color was where I wanted it and 3 minutes seemed to get me there. At first I thought I had done it too dark but out in direct sunlight it turned out to be a nice OD Green.
Ruudr
Post by Ruudr »
Thanks I’m going to try this recipe. It’s kind of difficult to get Rit Dye in the Netherlands but I managed. Now I need to wait for the Native 5 and dye to arrive.
How is the color holding up? Any signs of fading or that it comes off in the corners?
MidnightCoalCo.
Ruudr wrote:
Sat Jun 29, 2024 3:49 pm
So far the color seems to be holding up well, I haven't noticed yet any signs of it wearing off or fading. However, this knife is not my primary carry but one knife in a large rotation of knives I carry so that could be a factor into why I haven't noticed much wear on it.
