Grit estimation on Soyderco Benchstones
So I finally wore out my Spyderco Double stuff.
Even though I mostly use Atoma diamond plates or Naniwa Wahetstones for most of my sharpening, I liked having the ceramic hand sharpener for touch-up and quick honing.
I’m considering just buying the medium and fine benchstones to supplement the retired Double Stuff hone. Any idea what grit these are at?
Re: Grit estimation on Soyderco Benchstones
Mine behave like about 1500 and 3000 grit.
According to
https://www.chefknivestogoforums.com/vi ... .php?t=196
- medium is at 15 micron,
- fine at 6 micron
- and ultrafine at 3 micron.
- Manifestgtr
Hmmmm….Soyderco
What’s the crunchiest, most earth-friendly Spyderco? That’s the real issue here
Crucarta: Shaman (x2), Manix 2, Lil Native, Delica, GB2 & PM2
Favorites: Shaman, Sage 5 lightweight, Sheeps Caribbean, Manix, Endela and all things Stretch
Manifestgtr wrote: ↑Thu May 23, 2024 8:24 pmHmmmm….Soyderco
I don’t get it, but ok
Maybe you could lap your doublestuff on a diamond plate?
- Hopsbreath
This one’s 100% organic. https://www.spyderco.com/catalog/details/WDKIT1/789Manifestgtr wrote: ↑Thu May 23, 2024 8:24 pmHmmmm….Soyderco
It seems like these ceramic stones of Spyderco's are truly unique among most other sharpening stones on the market. For touch ups and minor sharpening jobs I find them to be indispensable. I take some of my Spyderco sharpening tools with me no matter where I go.
The 204 Sharpmaker is a genius idea. Spyderco's sharpening gear is every bit as high of quality as their cutlery is.
Not sure what grit equivalents the stones are but they are truly unique in the market of sharpening tools..
I agree.JD Spydo wrote: ↑Mon May 27, 2024 7:47 amIt seems like these ceramic stones of Spyderco's are truly unique among most other sharpening stones on the market. For touch ups and minor sharpening jobs I find them to be indispensable. I take some of my Spyderco sharpening tools with me no matter where I go.
My go to kit for touchups and quick sharpening jobs (when the edge isn’t in too bad of shape).
Ceramic stones are not graded in grits like sandpaper, where the abrasive particles pass through a specific size of mesh to be sized. We also use the same basic size of abrasive particles in all our stones. Their final coarseness is then carefully controlled through the other materials in the ceramic (“carriers”), the firing process, and, in some cases, abrasive grinding processes to achieve a final finish. By comparing the scratch patterns of sharpened edges to those sharpened by conventional abrasives, the following grit-size comparison may be made:
ULTRA FINE -- 2,000 grit
FINE -- 1,200 grit
MEDIUM -- 600 grit
Our diamond and CBN sharpeners are mostly 400 mesh. The CBN Benchstone (206CBN) is 400 on one side and 800 on the other. The Webfoot is 600 mesh.
I hope this helps.
Stay safe,
Mike
FINE -- 1,200 grit
MEDIUM -- 600 grit
I hope this helps.
Stay safe,
Mike
Re: Grit estimation on Spyderco Benchstones
@RazorSharp86 FYI, you can edit your first post and change the title to correct the spelling of Spyderco
Michael Janich wrote: ↑Wed May 29, 2024 7:08 amCeramic stones are not graded in grits like sandpaper, where the abrasive particles pass through a specific size of mesh to be sized. We also use the same basic size of abrasive particles in all our stones. Their final coarseness is then carefully controlled through the other materials in the ceramic (“carriers”), the firing process, and, in some cases, abrasive grinding processes to achieve a final finish. By comparing the scratch patterns of sharpened edges to those sharpened by conventional abrasives, the following grit-size comparison may be made:
FINE -- 1,200 grit
MEDIUM -- 600 grit
I hope this helps.
Stay safe,
Mike
Thanks for this, Michael.
I figured that the grit rating would be different, and was only but looking for a rough idea as to what they’d be comparable to, more or less. You gave me the answer I came looking for.
This is why I love the brand, and its people. Because communities like these exist, where you can get answers from ppl who give a dmn and know their stuff.
Much appreciated.
Dear Razordsharp86:
Thank you for the kind words. I'm glad I hit the mark.
Stay safe,
Mike
Stay safe,
Mike
