Steeltoez83 testing log
Steeltoez83
Re: Steeltoez83 testing log
Post by Steeltoez83 »
Factory edge was quite dull so I tuned it up. Ended up with 220 on my sanding roll with my HIC mule.
Steeltoez83
I have my technique dialed in for putting an edge on this material. The latest cut test reached 400 which nearly doubled the last one. The stone I used was the spyderco cbn benchstone- 800 side only. In a perfect world it only takes 5 minutes, but I will retest that. I'm hoping with my 40/20 style testing I can cause some damage to the apex. And recreate the same sharpness standard in 10 minutes or less. I'm still establishing a performance plateau level, so I'm thinking the next edge results will be what I use for the 40/20 ice block test.
In terms of sharpness, I'd say the material is deceptive. And to the fingerpads it doesn't grip how we are used to with carbides in steel. Even at an 800 grit finish, I'd say draw cutting is the most effective way to evaluate and use. I still prefer steel bcuz it has more grip when cutting across its alloys.
Steeltoez83
Latest cut test numbers pull it ahead of maxamet by 110. I plan on testing this guy along with zdp 189 tomorrow on the ice. Instead of 60% aka 40-20 ratio, I'm thinking of just extending it 7 days to reach 60% on this ceramic. 36 cuts and 18 ice chops per day.
My cut numbers for my zdp 189 endura was 390 from my records.
dan31
Post by dan31 »
ZDP-189 is still a favorite. Glad you are keeping it in your testing.
Steeltoez83
156 cuts followed by 78 chops on ice, then another 81 cuts to get 315 out of 390. Roughly an 81% efficiency rating. I have to mention that this knife was gifted to me by kurt for testing purposes.
Steeltoez83
The HIC mule wasn't able to pass day 2. After day 1 it was fine, but after day 2 it failed. It was still technically sharper at this point than when I received it. 2 days out of the benchmark 7 is a lot more brittle than I'd like to see. I'm deciding if it's the best course of action to do chops on a harder material next or not. Damage wise, not much but if I move to hitting a block of limestone, I might not able to do other testing.
Steeltoez83
400 grit cbn stone used for 3 minutes on my HIC mule. I expected it to exaggerate damage from the ice whacks but it didn't. It could be the damage was so small it just avoided it all together.
Giygas wrote:
Sun Apr 14, 2024 9:28 am
I've been following you for a while on YT. Really excited for this thread.
@Steeltoez83 or @Giygas, would you kindly share the YT channel?
Giygas
Post by Giygas »
Brock O Lee wrote:
Sun May 05, 2024 3:51 pm
Here's his channel:
https://youtube.com/@steeltoez8345
Currently testing: M398, D3, SLD-Magic
Favorites: 10V, s90v
Wishlist: S290, Vancron, S125V, K890
18 Spydies, 15 steels
13 Maxace, 9 steels
Giygas wrote:
Sun May 05, 2024 4:31 pm
Here's his channel:
Thank you! 👍
Steeltoez83
This week I'm testing an obvious clone of the buck 110 in 8cr13mov. I saw this at my local hardware store for 20 dollars. I haven't listed any spyderco 8cr testing results in this thread, so it should be a fun comparison. Build quality is very poor on the clone. Factory edge scored 35, 1st edge 70.
Steeltoez83
#32
Spyderco leafjumper in k390. One of my favorite carry knives. I have cut tested seki k390 before, but nothing for this thread. 475 is right where my stretch and delica tested before.
