Building a Custom Knife for Sal: CPM S60V
- Mr Blonde
Re: Building a Custom Knife for Sal: CPM S60V
Very interesting thread, thanks for posting and sharing all of this!
- Deadboxhero
All steel chemistries have a "chemistry range" these different variations of chemistry within that tolerance that can affect what goes into solution at a given temperature which will affect the hardness even at the same temperature requiring a shift up or down in temperature to match hardnesses from other melts.
It's always nice to characterize each melt of the same steel grade.
This chemistry information is not pertinent to consumers of finished products. This is just a fun look behind the curtain. So, hopefully it's not going to lead to any confusion or people chasing red herrings going too far into a rabbit hole without having other very pertinent information to put the whole picture into context.
Time to build a "map" for the heat treatment.
Trial conditions have to be well processed since they are going to be used to give an accurate representation of the characterization.
Each condition will require a different firing operation in the furnace, which can be rather time consuming. However, this gives a good "map" of the material.
The hardness itself doesn't tell the full story however it is very useful when using a curve to determine what's happening to the microstructure.
This is the max obtainable hardness I was able to achieve with this material using a well calibrated hardness tester. The condition averaged 66.4rc.
I won't use this hardness for the slicer but it's nice to see I can temper further down from this.
Now that my new batch is characterized and I've given some thought to the data it's time to heat treat Sal's knife, The first step is rather boring. It involves a stress relieving cycle which can take a long time since the furnace has to cool down overnight.
Stress relieving helps mitigate warping which, given the size of this knife, is a good practice.
Even at lower temperatures, atmosphere protection is important. So, the knife is sealed in a airtight, stainless steel envelope.
The next day, it's time for my favorite part of heat treatment which is the most exciting and most important.
Austenitizing.
Which is heating the steel up to the temperature we are going to harden from when it's cooled with quenching.
Next is quenching, which is when we trap the elements we put in solution in with austenitizing by cooling from there faster than they can diffuse.
Or simply put make....knife....hard.
Different types of steel have different needs from still air, forced air, plates, oils, water etc.
Not too fast yet, not too slow, all depending on the steel.
We'll get some oxide on the blade during quenching but it's nothing like the big nasty decarb scale we would see if we did not have the stainless steel envelope during austenitizing.
The blade came out straight which is always a plus.
There's no time to admire the freshly quenched blade. It is off to soak in liquid nitrogen to complete the quench.
Time delay here will stabilize features we want to convert with the cold treatment.
After soaking in liquid nitrogen, it's off to tempering and surfacing.
Austenitizing.
Hey Shawn,
What did you use for the quench?
- Deadboxhero
Large aluminum plates with forced air to race to under 1000f to prevent proeutectoid carbide precipitation on prior austenite grain boundaries.
Water when under~1000f to speed the cooling curve to reduce RA stabilization when cooling to room temp under 1000f.
A large piece like this knife I am making you requires a very demanding quenching regime much different than a smaller coupon or tiny blade.
For example,
1"x1"x0.100" will cool differently than 10"x 10"x 1.00"
Rapid continuous cooling with a good rate is very crucial for all steels to achieve the maximum performance.
For using 52100 however, I will use parks 50 which is a fast quenching oil.
Some simple carbon steels have such low hardenability perhaps only water is suitable.
But it's not something I've had to worry about with stainless steels.
Thanks for the Master Class, Shawn. The knowledge is ALWAYS appreciated.
- Deadboxhero
Thanks LQ.
I appreciate it.
Agreed; thank you Shawn. This really puts into a different perspective on why the prices of knives are what they are, and especially so at a custom level. I'm looking forward to what sal thinks of this S60V sample, and also with what you're doing with the 19C27 heat-treat.
Cheers brother .
Cheers brother .
Make Knife Grinds Thin Again.
Very interesting to have a peak into the other side of the curtain.
- WilliamMunny
Shawn,
How do you balance the need for rapid cooling but avoid warping, especially on such a big blade?
I would have guessed it would cool unevenly and worry on you.
Endura AUS-8, Manix 2 S30V, Alcyone BD1N, PM2 Micarta Cruwear, Native 5 Maxamet (2nd), Para 3 Maxamet (2nd), Magnacut Mule, Z-Wear Mule, BBB 15V Manix 2, REC PM3 10V Satin, Dragonfly Salt 2, GB2 M4.
- Deadboxhero
Warming back up to room temperature from -320F
Surfacing to a high finish with diamond abrasive belts
Testing between cycles.
- legOFwhat?
-Larry
MNOSD #0049
MNOSD #0049
- The Mastiff
Thanks for taking the time to document and explain the process as you go Shawn.
- WilliamMunny
Next time my wife asks me why my knives can cost so much I will send her to this topic.
In all seriousness, Shawn, how did you get into knife making? I am into wood working, for $1,000 bucks can get you started and produce nice stuff. With knife making it seems like you need to jump both feet in with huge money in equipment to do it correctly let alone the skill and knowledge.
Not sure if this is what you're asking, but he prevents warping by clamping the blade in between two big aluminum blocks. Helps it cool by dissipating heat into the blocks, and keeps it from warping by pressing it flat during the cooling process.WilliamMunny wrote: ↑Mon Apr 15, 2024 7:45 pmShawn,
Deadboxhero wrote: ↑Mon Apr 15, 2024 2:58 pm
For example,
- Deadboxhero
Heat treatment complete
Final hardness average after tempering was 64.5rc
This has got to be one of the most fun threads I've read in a while. Thanks for taking us along, Shawn.
- Deadboxhero
- Deadboxhero
Trevor inspecting the blade before moving on to grinding.
Nothing escapes his scrutinizing gaze.
Hehehe.....I'll bet not. He's doin a fine job.
he's getting big!Deadboxhero wrote: ↑Tue Apr 16, 2024 12:17 pm
