Lil Temperance 3 Pocket Clip
EduardoCurros
Post by EduardoCurros »
Hi Everyone,
Does anyone know.of a deep pocket clip for the lil temperance 3?
Re: Lil Temperance 3 Pocket Clip
Hi Eduardo,
Might be hard to find. The Lil' Temperance 3 has a dedicated clip.
Ramonade
Post by Ramonade »
EduardoCurros wrote:
Sat Mar 23, 2024 5:59 pm
Hi Everyone,
Do you mean for the original Lil Temperence 3 or for the Lightweight version (that is still in production) ?
If it's for the lightweight, looks like a Tenacious deepcarry clip would be compatible
EduardoCurros
Thank you so much it has been driving me nuts
w3tnz
Post by w3tnz »
Ramonade wrote:
Sun Mar 24, 2024 5:11 am
Hi Everyone,
It doesn’t quite look the same, if you compare the hole placement around the pivot.
I see, said the blind man.
riclaw
Post by riclaw »
The Native 5 LW pocket clip looks like it has the right hole spacing. The clip won't contact the scale in the factory location, though, so even if the clip attaches it will be a pocket shredder.
- Richard
w3tnz
Post by w3tnz »
riclaw wrote:
Sun Mar 24, 2024 6:20 pm
Pattern looks closer but still a different location in relation to the pivot, screw size is a factor to consider also.
Your best bet might be to reach out to someone like Casey at Lynch Northwest, dimensions from their website below for comparison.
Tenacious:
Clip Length: 2.1"
Clip Screw Hole Measurement (between center of each screw hole): 0.40"
Clip Screw Hole Diameter: 0.12"
Native 5 lw:
Clip Length: 2.1"
Clip Screw Hole Measurement (between center of each screw hole): 0.42"
Clip Screw Hole Diameter: 0.10"
Guts
Post by Guts »
So been down this rabbit hole before. Own the original G10 LT3, the new FRN LT3, and a Native 5. The hole spacing on the Native 5 is different even though the layout is the same. Native 5 is about .400" center to center for the bottom two holes and the Lil temp 3 is 0.500". If you check out the pocket clips on knifekits.com, they sell one that has 0.500" ctc hole spacing that'll fit. I bought one to try a couple years back and can confirm it'll fit. It's not super deep carry but much lower compared to the factory LT3 clip.
