What is the best application to tool steel for long term storage?
jmj3esq
Post by jmj3esq »
I have a lot of knives, specifically a lot of Spyderco tool steel blades. I store my "safe queens" in their original boxes, usually with OEM desiccant bags in the boxes. I also have larger desiccant bags in the safe to help prevent corrosion. Although I take these precautions, I from time to time find that my tool steel begin to develop surface rust, especially on the edge. I understand I could strop the rust away, but in the process im taking away the original factory edge, which I don't want to do on my high end, safe queen, knives. Ive used several CLP type protectants, but it sees they dry up or evaporate after long storage.
What is the best stuff I can apply to tool steel for long term storage? Something that wont break down, evaporate, or leave me with a rusted edge. Maybe some sort of heavier wax? Let me know what you guys use for this. Thanks!
Re: What is the best application to tool steel for long term storage?
i've had good success with frog club paste.
Danke
Post by Danke »
RustyIron
Post by RustyIron »
jmj3esq wrote:
Sat Mar 09, 2024 6:36 am
Cosmoline. It's too messy for my purposes, but you asked. I've had guns that were coated many decades earlier, and they looked fine.
Birchwood-Casey's Barricade is a more sensible solution for long-term storage. If you want to take it one step further, seal each knife in a vacuum food storage bag.
Bill1170
Post by Bill1170 »
Chapstick seems to hold up well. I think it’s a blend of wax and petroleum jelly.
dsvirsky
Post by dsvirsky »
Briwax also works very well.
bdblue
Post by bdblue »
RustyIron wrote:
Sat Mar 09, 2024 11:25 am
This is the stuff I use and it performed the best in my informal test. You can search the internet and find tests done by various people including Project Farm. I have Ren Wax and I tried it in my test but it didn't do very well. I also have the glycerine-looking stuff sold by AG Russell, it didn't do very well in my test either.
zhyla
Post by zhyla »
I think sword people use wax based products. The chapstick idea above seems like it would work well.
Really anything that stays put and blocks out moisture and oxygen will work.
Naperville
Post by Naperville »
Sat Mar 09, 2024 7:04 am
This product is what many museums use to keep iron/steel Medieval artifacts from rusting away.
I bought it. It is not messy like an oil or lubricant that will be all over everything and destroy paper and boxes used to store knives.
You really have to be gungho to coat 100 knives. I had around 100 knives when I bought Renaissance Wax, and I took a look at the pile of knives, thought about the amount of time to coat the blades and said "No Thanks." Now that I've sold half of the knives I may give it a shot.
I am going to get a few very good quality clean cotton hand towels and one at a time dip the towel in the wax, then quickly coat the blades the best that I can. I do not own Tutankhamen's Knife....and the value of each of my knives is under $400 each I would think. I do not want to take a week, just a few hours max.
kennbr34
Post by kennbr34 »
Bill1170 wrote:
Sat Mar 09, 2024 12:57 pm
Yeah, chapstick is my favorite. Cheap and easy to apply and is really stable. Plus it's non-toxic, so that's nice to not have to worry about washing my hands afterwards.
Barricade also works well from what I have seen on my gun barrels, but I don't really like leaving it on outer surfaces because it seems to be easily wiped away.
One interesting thing I have heard recommended is a mixture of beeswax, petroleum jelly and mineral oil. The mineral oil helps with application, like sinking into crevices, and then when it disappears the beeswax helps keep the petroleum jelly more stable. I haven't tried it because it seems like Chapstick does the same.
JoviAl
Post by JoviAl »
I rate Marine Tuff Glide, but my gosh does it stink.
- Al
Work: Jumpmaster 2
Home: DF2 K390 Wharncliffe/DF2 Salt H1 SE and K390 Police 4 LW SE/15V Shaman
Dream knives -
Chinook in Magnacut (any era)
Manix 2 XL Salt in Magnacut
A larger Rockjumper in Magnacut SE
arty
Post by arty »
I use the Lee Valley Conservator’s wax. It works well.
https://assets.leevalley.com/Size4/1010 ... f-0022.jpg
Matus
Post by Matus »
Frog Lube - it is food safe. There are stronger rust-protecting agents, but I would rather not have on surfaces that might get in contact with food.
Here you can find a very detailed comparison of over 40 anti-rust agents
https://dayattherange.com/?page_id=3667
Scandi Grind
Post by Scandi Grind »
I would use Frog Lube because I have a jar and it's food safe. Otherwise I'd be thinking the chapstick option from the other suggestions here, seems like a easy option if it works well.
-- Old Norse proverb
SpyderJunky
Post by SpyderJunky »
I like Corrosion X.
Highly mobile on the metal surface and has a polar molecular bond to metal that can be best described as similar to magnetic.
It resists removal by detergent, alcohol, heat, and friction etc.
Also said to be bio-safe in quantities that might be transferred to food from a knife...
Imho, it is head and shoulders above It's competitors in the marine saltwater environment.
2 cents.
Airlsee
Post by Airlsee »
SpyderJunky wrote: I like Corrosion X.
I use Frog Lube paste...it's worked great for me and will probably last for at least another decade, but I'd never heard of Corrosion X, it definitely seems interesting, thanks!
So it goes.
JayHenMac
Post by JayHenMac »
I'm an Eezox fan for my guns and non-food knives.
Dullededge78!
Post by Dullededge78! »
I stored a lot of knives some with 1095 some with ELMAX and several other steels in a suitcase in a house for 10 years all I did was lubricate them with sentry oil and wrap them in bubble wrap . The house was in a temperate climate without ac as it’s not needed . I had 0 issue with any apart from a slight bit of rust on an essee and that was only on the laser engraved logo .
GT99
Post by GT99 »
Fluid film works great, havent even gotten so much as a patina on anything because of it, rain, sweat, fruit....no issues.
