New(ish) Delica is covered in surface rust
w3tnz
Re: New(ish) Delica is covered in surface rust
Post by w3tnz »
swidgen wrote:
Fri Feb 23, 2024 11:43 pm
EDIT: I didin't know this forum got so much action or I would have stayed on to answer every question. I also followed the directions of one of the posts to put up pictures. the knife is VG-10 no doubt and the rust is more than surface. I tried spraying it (soaking it0 WITH WD-40 and wrapping it with saran wrap and leaving it for a weak. it didn't help a bit. this knife is less than a year old. my last one made it minimum 10 years, but probably closer to 15 without a spec of rust, although lots of har ww=are and character.
Also. I cant for the life of me find where they responded that they had changed the formula of the VG-10 which is why it might be rusting. i wanna know what the **** is going on
Man, it looks like you rode it hard and put it away wet! Is that salt residue on the handle?
You will need something abrasive, try a polishing compound on a rag to start - autosol, mothers or similar. If that doesn’t cut it move up to steel wool or some fine sandpaper.
If you are comfortable disassembling it I would also recommend that as the rust is likely in the pivot and maybe liners also, good luck.
I see, said the blind man.
JoviAl
Post by JoviAl »
If it’s any consolation my VG10 does that if I forget to spray it with marine tuf-glide after I clean it. It looks rough but with a rust eraser it comes straight off and is none the worse for wear after a touch up sharpening.
*edit - added a picture of the rust eraser. It doesn’t just do rust - it also cleans up sharpening stones really quickly of buildup.
- Al
Work: Jumpmaster 2
Home: DF2 K390 Wharncliffe/DF2 Salt H1 SE and K390 Police 4 LW SE/15V Shaman
Dream knives -
Chinook in Magnacut (any era)
Manix 2 XL Salt in Magnacut
A larger Rockjumper in Magnacut SE
Bill1170
Post by Bill1170 »
Swidgen,
I concur that your Delica appears to have rusted after cutting something. The ricasso behind the plunge appears unaffected. Some Bar Keeper’s Friend should fix you right up.
Bill1170 wrote:
Wed Feb 28, 2024 9:59 pm
Swidgen,
That´s what I strongly assume too - but actually on one side (where VG10 is marked) the ricasso does show a bit of rust too. But it is actually on the left side, where a right handed person often tilts the knife towards matter that gets cut, so the ricasso there might have very well come in touch with whatever corrosive material too,
