Sharpening a FB01 Moran
john row
Post by john row »
Some advice please. How best to maintain the original geometry?
John Row
colobbfan
john row
Post by john row »
I need input please!
John
Hi John. If it's the "hamaguri" grind, only a buffer will really work. If it's the satin finish flat grind, use the sharpmaker as normal.
john row
Post by john row »
Thanks Sal.
John
From Golden, Colorado and the knife cuts HAVE caught up to the paper cuts :)
Onehandclapping
Post by Onehandclapping »
Hello,
I've had good results using a leather belt in a small belt sander, like 1X30 cheap one from any hardware store. I use fine rouge on the belt and lightly wipe the blade across the moving belt with the blade edge pointing DOWN. Otherwise you'll just cut the belt in half VERY quickly. Be gentle and take you time. Good luck
john row
Post by john row »
Thanks OneHandClapping
John
