Thinking about running the four max elite with titanium liners and hardware without the scales and adding a hole where the thumb stud is. What do you think? Here is a mock up.
Re: Four!!!! Hole in 1, 4Max? Ti Max?
Posted: Mon Dec 11, 2023 9:28 pm
by Naperville
Might work. I like the model too...
Posted: Mon Dec 11, 2023 9:41 pm
by vivi
I'll be watching to hear how the spydie hole mod works.
Posted: Mon Dec 11, 2023 10:02 pm
by Naperville
I like the stainless, but there is always the option of using 3M grip tape for one side. I'm thinking about buying some for my knives.
Right on.
If Fireman has laser or EDM capabilities, it might be pretty easy.
The best I could do would be a carbide fly cutter with a lot of coolant, and my expectation would be an ugly hole and damaged tools.
Posted: Mon Dec 11, 2023 11:29 pm
by Fireman
I used diamond bits in my Makita to do this hole in the Mayhem. I modded it quite a bit.
...6mm shank diamond bits in my Makita hand drill...
Well I'm gobsmacked! I did not know you could do that kind of work on hard steel with a hand drill!
Posted: Tue Dec 12, 2023 2:46 pm
by Fireman
Took about an hour
Look at this for tips but I did fine with a hand drill.
Posted: Tue Dec 12, 2023 6:26 pm
by Fireman
Here is a start. Probably make it a bit bigger
Posted: Tue Dec 12, 2023 7:37 pm
by Bolster
Dude in the video uses a carbide bit to roughly enlarge the hole. I assume diamond bit works as well, maybe better?
Posted: Tue Dec 12, 2023 7:47 pm
by Fireman
I haven’t used carbide, but diamond seems to work. OK just takes a while and dirty. I also used diamond files
Posted: Fri Dec 15, 2023 1:23 am
by Fireman
Well she is about 95% the way there. She is a butter knife right now (Butter face) Had to alter and or shorten all the hardware to make it work but it now carries like a dream and you don’t feel like you are carrying such a huge knife. I will probably do some satin finish and or some flame design since the scales are Titanium. Voila! Kind of industrial minimalist.
Posted: Fri Dec 15, 2023 2:16 am
by RustyIron
That's NICE! Holes are the way to go. Post pictures of the colors you create.
Posted: Fri Dec 15, 2023 7:25 am
by vivi
lookin good! think you'll contour the scales some or leave them as is? how's the opening arc for the hole? does the guard get in your way at all?
The guard was getting in the way little bit so I took some off. I’m just leaving the liners without scales. Opening ark is great
I had a feeling that would be the case. I'd love to mod some of my CS folders with opening holes. The studs work but they're not nearly as good as the spyder hole.
