Cerakoted my 15v Mule
Didn't want to have to deal with tarish/rust. I think it looks pretty good in flat black.
Re: Cerakoted my 15v Mule
I like it!
Very nice. Did you do Cerakote at home, or did you have it done?
Nice job! I too would like to know how you did it. I might need to ceracote and plasti-dip some of my mules
Mule Team Army 001
MNOSD 008
MNOSD 008
A guy I shoot PRS matches with cerakotes part-time. He did a great job.
Hi Emerson,
Welcome to our forum.
Chef's kiss ... mmmwah! Looks phenomenal.
- Fastidiotus
Never thought about a coated mule... Now I want a coated mule.
Not a Mule but he did my 15v shaman and Ti scales too.
Looks great! I originally thought about doing this with my 15V, but it has been more corrosion resistant than I expected. Maybe because of that nice bead-blasted finish?
Regardless, seeing how good your black on black on black mule looks, and now I'm thinking about it again. I have a T15 and K294 that would probably be good candidates, as the satin-like finish on those models is rather coarse and I have noticed a little more spotting on those.
I like what you/your buddy did with the shaman, too! Looks super clean and streamlined.
barnaclesonaboat wrote: ↑Wed Dec 06, 2023 2:10 pmLooks great! I originally thought about doing this with my 15V, but it has been more corrosion resistant than I expected. Maybe because of that nice bead-blasted finish?
I think the 15V is stonewashed. Bead blasting reduces corrosion resistance because it increases surface area, so there are more nooks and crannies for moisture to adhere to.
Can somebody give a ballpark idea of cost for cerakoting a mule?
In France me and my friend found a place that would cerakote a full Valloton for 68€. I guess a Mule would be cheaper (this answer is just to give a ballpark until someone answers truthfully)
MNOSD member 004* aka Mr. N5s
On a rifle I did some parts in Duracote. It's similar to Ceracote, but it comes in a rattle can. It went on nicely, laid out flat, and it's still unblemished. One kit cost me about $50, and it's enough to do a LOT of knifes. The caveat is that the product doesn't last long after you initially shake up the can.
So my Mule, Shaman blade, Ti scales, and the shaman clip/screws/interior plates were $75 all together. That's full price with no buddy hook up. So I don't think just a Mule would cost more than $30. It will most likely hurt collector/resell value but I don't care as I plan on using mine regularly.
RustyIron wrote: ↑Thu Dec 07, 2023 1:27 pmOn a rifle I did some parts in Duracote. It's similar to Ceracote, but it comes in a rattle can. It went on nicely, laid out flat, and it's still unblemished. One kit cost me about $50, and it's enough to do a LOT of knifes. The caveat is that the product doesn't last long after you initially shake up the can.
I wonder if it's some sort of two-part epoxy that can be sprayed? From your descrip, it sounds like some sort of catalyst action is going on...
It is a two-part product. You can buy it in individual cans for use in your spray gun, but I chose the simplicity of the rattle can. There's a little widget inside the can that contains the hardener. Once you mix it up, it's best to use it soon. It won't last on the shelf.
Good **** sir! What cerakote color did he use? Had a Rex76 done in armor black and a ZDP-189 second done in sig grey. Just finished sharpening a T-15, working on a K294, then a 15V before dropping them off for cerakote.
LR Black
"Cerakote’s® unique inorganic LR Black is a low-reflective light-absorbing black coating, designed to absorb visible light spectrum wavelengths."
