I wanted to give my para 3 LW a more blacked out aesthetic by swapping the chrome screws for black ones.
I've sent an email to Spyderco and they could only give my the clip screws. This was what they told me.
"We apologize, but we can only provide the clip screws. For any other screw you would need to send the knife in to our warranty and repair department."
Help with the black screws
Michael Janich
Re: Help with the black screws
Dear Rearight:
Welcome to the Spyderco forum.
If you lose a single assembly screw, we recommend taking a photo of your knife pointing to the missing screw and sending it to us. We will send a replacement for that screw.
Choosing to modify your knife with all new hardware is a very different matter. It is not the manufacturer's responsibility to fund that activity. If you want all-black hardware for your Para 3 Lightweight, here's a commercial source: https://www.knivesplus.com/replacement- ... steel.html.
Stay safe,
Mike
Stay safe,
Mike
Thanks! When did they start making hardware for the lightweight?
- Richard
You can check "screw4you" on Etsy. I've gotten a few sets of colored screws from them.
The barn door is open wide but I’m not going in
Mule Team Army 001 (patched)
MNOSD 008
Stable Mules; Z-Max, Z-Wear, Magna Cut, Magna Max, SRS13, Rex 76, Rex T15.
MNOSD 008
Stable Mules; Z-Max, Z-Wear, Magna Cut, Magna Max, SRS13, Rex 76, Rex T15.-
RegularJoeKnife
Applied Weapons Tech now has Para 3 lightweight hardware replacement in stainless as well as titanium. Full set replaces all hardware. I have tried them and they fit and work well. I damaged my stop pin and was able to replace it and screw in both sides without issue.
